It is currently Sun May 03, 2026 11:56 pm
 Post subject: Dual 45 Dellorto Problem
PostPosted: Sat Jan 28, 2012 8:37 pm
A buddy of mine is trying to put a set of dual 45 dellorto's on his 1915 just wondering what jets should be in it. idle jets=60,high speed=80,immulsion tubes= f11 thats about all i know we've done about al we can do other than use them as boat ankers lol
PostPosted: Sat Jan 28, 2012 8:55 pm
Are the mains 80? or 180 . What is it doing or not do
PostPosted: Sat Jan 28, 2012 9:12 pm
Its popping and cracking real bad and the might be 180's ill have to look again but we've had them apart 4 different times and nothing looks stopped up
PostPosted: Sat Jan 28, 2012 10:17 pm
intake leak ?
PostPosted: Sat Jan 28, 2012 10:24 pm
jesse wrote:
intake leak ?
after you get running spray a little starting fluid around the gaskets to see if engine idle picks up.you are getting to much air sounds like.chad :mrgreen:
PostPosted: Sun Jan 29, 2012 8:41 pm
Are they in sync. And do the 4 idle -mixture adjustment scews work . If not look for intake leak.
PostPosted: Sun Jan 29, 2012 9:37 pm
Popping at idle maybe idle jet or idle circuit blocked . Will it run at med to hi RPMs?
PostPosted: Sun Jan 29, 2012 10:19 pm
Runs good at high rpms seems like u clean one thing and something else goes wrong
PostPosted: Mon Jan 30, 2012 8:04 pm
Clean gas tank fuel fillter and carbs . Idle jets and ports are small .
PostPosted: Mon Jan 30, 2012 9:10 pm
Still could have a bad seal on your gasket. I've seen them leak and when you open it up it would run fine.guess it was sucking it down tight or something.the elusive carb monster.every now and then you can catch one and get rid of them.but everynow and then they get in and out, and leave little turds everywhere to figure out how to clean up.Chad :mrgreen:
PostPosted: Mon Jan 30, 2012 10:53 pm
Man I like how dual carbs make a motor come to life but you'll hate them til you get them right
Thanks for all the help
