It is currently Mon May 04, 2026 10:46 am
PostPosted: Thu Jan 26, 2012 5:12 pm
Wondering what u guys run for throttle cable and how.......
PostPosted: Thu Jan 26, 2012 5:54 pm
i use a throttle cable :lol: :lol: :lol: :lol: :lol: :lol: just kiddin! you can use any thin cable and rig it up somehow, personally mine runs thru a piece of 3/8 copper tube from by the peddle to back before the shroud then hooks up to a cb performance diffent kinda ,to hard to explain :roll: but you should run it thru the shroud to keep the cable from being worn or gettin frayed. and i use copper cause it doesnt rust like brake lines do :wink: which is another way of running it to the back! hope this helps
PostPosted: Thu Jan 26, 2012 6:06 pm
morse cable is a clean option buy it cut it to length and install with clamps along the center pipe of buggy floor. alittle costly but real effective and clean looking.
PostPosted: Thu Jan 26, 2012 6:52 pm
I'm using 3/8 hyd hard line lined with ice maker line in side so the cable will not rust and hang up. Been running it that way for 3 years with no problems.
PostPosted: Thu Jan 26, 2012 7:05 pm
Morse cables are nice and clean,but you can get some small plastic tubing run some small cable through it,or copper tbg. You can get the little boots off a ten speed cable and put on the ends to keep mud and water out.Chad :mrgreen:
PostPosted: Thu Jan 26, 2012 7:32 pm
Morse cable hands down is better.
With other setups, when you get water and mud in the tube with your cable, it can freeze on a cold morning, leaving you with no throttle.
We've had that happen more than once.
PostPosted: Thu Jan 26, 2012 7:35 pm
the first thing on this link and the cable that my local buggy shop has
http://www.dansperformanceparts.com/bug ... ytcbh3.htm
PostPosted: Fri Jan 27, 2012 6:15 pm
I was running a Morse cable $$$ only problem was they are next to impossible to lubricate. After time they will stiffen up without lube. On my current project I will use plastic tubing with stainless cable. That way I can force oil through it to keep it lubed and since mine has a fiberglass body, water getting in shouldn't be a big issue.
PostPosted: Fri Jan 27, 2012 8:33 pm
Mine is 10 yrs old,and no problems yet.
I've never lubed it, but it does have rubber seals on each end.
PostPosted: Fri Jan 27, 2012 10:06 pm
I work at a truck fleet shop so mine is a stainless trailer roll door cable run thru air brake tubing . Already has a eyelet for the pedal end and cut it into with a welder at the carb end so it wont unravel
Users browsing this forum: Google [Bot] and 8 guests
