It is currently Mon May 04, 2026 1:48 am
 Post subject: small alternator pulley
PostPosted: Mon Jan 23, 2012 12:09 am
has anybody used these with the small drysump crank pulleys
http://www.lowbugget.com/speedpulleys.html
PostPosted: Mon Jan 23, 2012 12:11 am
No experience with it, But doesnt doing that change the fan speed and mess with the cooling ability?
"IT IS WHAT IT IS"
PostPosted: Mon Jan 23, 2012 12:24 am
the smaller crank pulley required with a drysump slows down the fan/alt speed = less cooling, so putting a smaller alt pulley on should speed it back up
i think of like the crank pulley being the front sprocket and the alt pulley being the axle sprocket on a 4 wheeler, and for example changing 1 tooth on the front sprocket was = or has the same effect as a 3 tooth change on the rear sprocket
smaller on the drive sprocket = lower gearing
bigger on the drive sprocket = higher gearing
and the rear/driven spocket is right the opposite
smaller axle sprocket = higher gearing
bigger axle sprocket = lower gearing
hope this didnt confuse anybody
PostPosted: Mon Jan 23, 2012 1:23 am
bigger buds + new bong= great high :mrgreen: you threw me off so bad with that math i had to do that :D
PostPosted: Mon Jan 23, 2012 4:57 am
Now that we went to sprockets I understand completely lol :mrgreen: :mrgreen:
"IT IS WHAT IT IS"
PostPosted: Mon Jan 23, 2012 2:35 pm
yeah i just dry sumped my buggy and had to put a smaiier pully on the alt to speed it back up so it can cool and charge right at idal. not cheap eather 85 dollors for that one pully :o
PostPosted: Tue Jan 24, 2012 10:41 am
We have the "dry sump alt pulley" that is made of aluminum and hard anodized so wear is not a factor and does speed the alt/fan up for better cooling/battery charging....uses factory shims to adjust belt. You will see many of these on the buggies that ride D & K often and never have any problems. They cost $84.95 each and I would ship at no charge to woodsbuggy.com members! Thanks 513-868-9543
