It is currently Mon May 04, 2026 9:14 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Wed Oct 24, 2007 7:02 pm
I just had to modify the stock lever on the tranny and make a peice of linkage to connect to Turboblue's shifter, it works pretty slick. I mounted the shift linkage on the floor to get it closer to the pivot point of the tranny rod/lever.
There is also a spring inside the nose which should be removed, but it is easy, take off the nose and find this...
http://i141.photobucket.com/albums/r43/ ... G_0115.jpg
Remove the two c-clips that hold the shaft in...
http://i141.photobucket.com/albums/r43/ ... G_0116.jpg
Pull the shaft out, remove the spring, re-assemble...
http://i141.photobucket.com/albums/r43/ ... G_0117.jpg
http://i141.photobucket.com/albums/r43/ ... 0118-1.jpg
PostPosted: Fri Dec 14, 2007 1:00 pm
That is gonna be a sweet setup. BTW I posted earlier about the econo rack maybe not having enough turning radius and that I had already moved the stops back. Well I took it off and slotted the plates on the bottom all the way to the stop with the bolt removed and WOW is it nice now. 8)
