It is currently Mon May 04, 2026 3:55 pm
 Post subject: ive got a ?
PostPosted: Wed Jan 11, 2012 2:51 am
does anybody know if they make a double ended stud with 3/8-24 on one end and 8mm x 1.25 on the other end, if anybody knows if this type stud is made please let me know where i might find them i dont seem to be looking in the right places, if they even exist that is :?
 Post subject: Re: ive got a ?
PostPosted: Wed Jan 11, 2012 3:20 am
http://www.racebolt.com/tubular_bolts.htm
i dont know exactly what im looking for lol but do you see it here
PostPosted: Wed Jan 11, 2012 3:40 am
http://www.fastenal.com/web/search/prod ... 53wr&Nty=0
PostPosted: Wed Jan 11, 2012 3:50 am
i added a pic
yeah jesse i already checked fastenal but all i found were same diameter with same or different thread pitch, and i need different diameter on each end
PostPosted: Wed Jan 11, 2012 10:31 am
Have you tryed McMastercarr
PostPosted: Wed Jan 11, 2012 12:39 pm
Best you'll get is 3/8-24 on one end and 3/8-16 at the other, same with 5/16.
They can be made :idea:
PostPosted: Wed Jan 11, 2012 6:52 pm
Take a jug stud cut it off the length you want ,thread the other end with the 3/8 the other end will be 10 mm .I have done this to make longer bottom trans mt studs.Don't know if this helps or not
PostPosted: Wed Jan 11, 2012 9:22 pm
VW rocker studs are 10mm on one end and 8mm on the other!
PostPosted: Wed Jan 11, 2012 9:45 pm
My best guess would have been McMasterCarr also, other wise if you have access/knowledge make your own 8)
WTFO
Loud pipes save lives.
PostPosted: Thu Jan 12, 2012 5:55 am
thanks for the input guys 8)
finally got the size i need figured out
probably have to get them made at a machine shop i guess
PostPosted: Thu Jan 12, 2012 1:08 pm
What exactly are you trying to do?
PostPosted: Thu Jan 12, 2012 7:19 pm
ive got a new set of cb performance bolt on valve covers im trying to use but the problem is the pauter rockers im also using, they come with bigger (3/8) and studs and barrel nuts and the rubber sleeve that comes with the valve covers is already a tight fit with the 8mm studs that they are meant for
PostPosted: Thu Jan 12, 2012 7:28 pm
Goto pullapart and get a nissan valve cover, cut it down and jb weld it on there. It will be good. :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Thu Jan 12, 2012 7:31 pm
i like him, but i aint as smart as dd lol :lol: :lol: :lol: :lol: :lol: :lol: :lol:
PostPosted: Thu Jan 12, 2012 8:35 pm
Been there,done that. Just drill the cover out so a 3/8" stud will go through it. Then use early oil cooler seals around the studs. I tig welded the studs into the barrel nuts so that they would stop working loose and use locking type nuts.
