It is currently Mon May 04, 2026 11:59 am
 Post subject: need some help
PostPosted: Tue Dec 27, 2011 3:22 pm
I finally got to start working on the buggy. I started going threw some of the parts that came with the buggy that Iam not going to need so I can try a sale them. Here is where I could use a hand. The motor that was on the buggy was a vw and the guy I got it from said it was a 2000 plus cc long story short he blew it up and destroyed most of it. I still have the heads crank and carb and intake. How can I tell what kind of heads they are. If it is for sure a stroker crank.
 Post subject: Re: need some help
PostPosted: Tue Dec 27, 2011 3:52 pm
Should be some kinda stamping on the heads,measure your valves.hillaholic had a post on here showing you how to measure the throw on your crank,but cant remember the topic heading.but search ac engine index,sure there is a post with pics in it somewhere on this.Chad :mrgreen:
PostPosted: Tue Dec 27, 2011 5:20 pm
the end of the crank that the pulley goes on opposite the flywheel should have the Number stamped on it. You may get numbers off head and look them up on The Samba.com. if you can't find the link on here.
PostPosted: Tue Dec 27, 2011 6:22 pm
thanks i will get out to the shop to nite and see what i can find out. Just trying to un load some of the stuff i dont need to get some cash for stuff i do.
PostPosted: Tue Dec 27, 2011 8:05 pm
Don't reuse your old oil lines cooler or filter after a blow up. It will release metal back into your new motor.
PostPosted: Wed Dec 28, 2011 1:18 am
If ya wanna load your stuff up and drive an hour or so south Im in Newark and would be glad to lend you a hand or you could text me pics pm if you want and Ill send ya my number
PostPosted: Thu Dec 29, 2011 5:09 pm
sent pm Mudd Mutt
Users browsing this forum: No registered users and 8 guests
