It is currently Mon May 04, 2026 12:16 pm
 Post subject: 6 rib question
PostPosted: Fri Dec 16, 2011 1:34 am
i have a stock 456 and want to change it to something lower other than 542 what can i put in it will a side shift 486 work being they are 091
 Post subject: Re: 6 rib question
PostPosted: Fri Dec 16, 2011 1:35 am
to be clear i want to keep my 6 rib but change the gearing in it to something lower
PostPosted: Fri Dec 16, 2011 1:47 am
as long as it is 091 it will work the only difference between side and nose shift 091's is the shifting setup, the entire gear stack and ring and pinions are the same or so thats what ive been told several times by different folks
PostPosted: Wed Jan 04, 2012 7:57 pm
jus buy a really low 1st and 2nd
PostPosted: Wed Jan 04, 2012 8:14 pm
I see what your sayin but what are you after? Wheel speed, just lower gearing, maybe try running a shorter tire to put more power to the ground?
PostPosted: Wed Jan 04, 2012 8:26 pm
I believe most of you southern boys would run 40's if you could get the gearing,I like Chris comment,a lower first and second would be another option.Chad :mrgreen:
PostPosted: Wed Jan 04, 2012 8:30 pm
Not sure but isn't the 5.42 stronger than say a lower ring,just curious if it is the gears would be better to change.this a good question Jesse.Chad :mrgreen:
PostPosted: Wed Jan 04, 2012 9:46 pm
5.42 is the third strongest stock ratio, only 4.86 and 4.57 are stronger.
PostPosted: Wed Jan 04, 2012 9:59 pm
Eric Debord swapped my 4.57 for a 4.86 from a side shift but he needed to do a little machining,,,I also swapped out my first and second gears
PostPosted: Thu Jan 05, 2012 3:05 am
that wont work jon, if it aint running at least Q Buckshots you pissing in the wind :lol:
PostPosted: Thu Jan 05, 2012 8:35 pm
Quote:
jon williams wrote: maybe try running a shorter tire to put more power to the ground?
:shock: :shock: im not getting rid of my buckshots :lol: :lol: but ima leave the trans as is its doing great
