It is currently Mon May 04, 2026 4:38 pm
PostPosted: Fri Nov 25, 2011 9:57 am
I have been reading and I want to confirm this question. If I buy a set of 2x3 trailing arms and a 5 rib bus transaxle which I already have can I use a set of bus axles like they sell on ebay for 150 for the pair with cvs and all? I am just trying to keep price down as much as possible not concerned badly with strength on the axles as of now just the travel.
PostPosted: Fri Nov 25, 2011 10:01 am
yes you can
PostPosted: Fri Nov 25, 2011 10:14 am
Yep that's correct , most of us cut the stops off the torsion to get more travel out of the suspension then we put limit straps on to stop cv bind .
When I have intstalled 2x3 arms I had to adjust the torsion tighter due to the arm having more weight leverage which made the buggy sit lower .
Then I got sick of messing with the torsion so I put bags on it and wow it rode like a caddy !
Golly I'll stop now , im writing a book ! good luck
PostPosted: Sat Nov 26, 2011 2:21 am
i would buy these if i was going that route, they have a lifetime warranty
http://www.autozone.com/autozone/parts/ ... 498%2C4024
ps i wouldnt mention nothing about a buggy or they get all confused, at least around here they do :roll:
PostPosted: Sat Nov 26, 2011 5:38 am
Just remember that Price is proportional to Quality... (Most of the time)
CV joints and Axles are one of the week links on a buggy and not the best place to find the cheapest parts. Breaking a CV or Axle on the trail is NEVER fun.. :shock: :shock:
PostPosted: Sat Nov 26, 2011 11:33 am
I bought some axles from advance with the life time warranty. The only problem i had with then was the fact that the splines on the axles were different. I broke a joint in the woods and couldnt fix it because or that. One axle had vw splines and the other one didnt.
PostPosted: Sat Nov 26, 2011 4:29 pm
Thanks only problem with that is the 75.00 core which I don't have even a reg vw. I just want to get it going so I don't loose interest and me and my kid can enjoy building it.
PostPosted: Thu Dec 15, 2011 3:20 am
Will this also work for stock car trans and cV's?
Without failure there is no success. We must be allowed to fall so we learn a better way to get up.
PostPosted: Thu Dec 15, 2011 8:25 am
yes you can 2x3 arms with a car trans but you keep the car cv joints and use bus axils
PostPosted: Thu Dec 15, 2011 9:57 pm
What kind of cost is involved with bus axles? Im a noob lol
PostPosted: Thu Dec 15, 2011 10:28 pm
give drews a call or see if any body on here has a set for sale they need to be 18 3/4 " long for 2x3
PostPosted: Fri Dec 16, 2011 12:48 am
bus axles are used with 2x3 arms and bus tranny, car tranny and 2x3 arms require longer than bus axle but not sure what the length is though
