It is currently Mon May 04, 2026 5:19 am
 Post subject: front arms
PostPosted: Wed Aug 03, 2011 9:45 pm
extended front ball joint arms 1" wider 2" longer, I'm not done with them I'm going to box them in
http://i282.photobucket.com/albums/kk26 ... G_0237.jpg
 Post subject: Re: front arms
PostPosted: Thu Aug 04, 2011 11:57 am
Nice job! Thats exactly the way I've been thinking of doing mine.
PostPosted: Thu Aug 04, 2011 4:19 pm
the only thing i was wondering is if the balljoint has enough travel to work properly. because the longer arm means more travel wouldnt it? idk maybe im wrong. lol wouldnt be the first time. :roll:
PostPosted: Thu Aug 04, 2011 5:39 pm
Longer arm = more travel for the same angles...
PostPosted: Thu Aug 04, 2011 7:03 pm
Use clearenced ball joints since there are none in there now ??? Even more travel... :idea:
PostPosted: Thu Aug 04, 2011 7:34 pm
That's what I'm going to use there not but a couple bucks more
PostPosted: Thu Aug 04, 2011 9:34 pm
Southern Buggys / WB Sponsor
KING PIN......I've got a ball joint for sale if anybody needs one.....Still a nice looking fab job
PostPosted: Thu Aug 04, 2011 10:39 pm
i was able to get six degree more by prepping the ball joint and could have went more but want to put then back on my buds front end and ck everything first . i found a set of balljoints that are much higher angle that i am going to try a full long travel balljoint front end .
PostPosted: Thu Aug 04, 2011 10:58 pm
the more they travel the quicker they will fly apart maybe someone should try to use a larger ball joint Just an idea
PostPosted: Fri Aug 05, 2011 1:38 pm
How much are you asking for the ball joint front end?
PostPosted: Fri Aug 05, 2011 7:34 pm
$75.00 right of the front of my buggy. Im keeping the box,ties,rotors,calipers.
PostPosted: Fri Aug 19, 2011 10:24 pm
There done
PostPosted: Thu Dec 15, 2011 12:47 am
Those look strong,but what keeps machied piece in the beam from bending or breaking?
PostPosted: Thu Dec 15, 2011 9:23 am
good question,,,the longer the arms the more stress on the other end. I had my bottom arms bending so I built a new set and inserted a thick walled tube in with a inner dimension just big enough for a threaded thru-rod,,,now the upper arms are the weak link and are bending some.I will eventually rebuild those as well and go with exterior spring of some sort.
PostPosted: Fri Dec 16, 2011 9:22 pm
Without going to thru rods there really is no good way to make a arm strong. You can weld all the stuff you want on the outside,but the part in the beam will break or bend.
PostPosted: Mon Jan 09, 2012 8:54 pm
^^ What he said, getting rid of the stress from the torsion leaves helps a fair bit too, it's amazing how much lighter you can make a front arm with coilovers up front.
Tube on our new arms that goes into the beam is only a tenth of an inch wall thickness, apart from the insert that the through-rods bolt up to/thrust bearings run on, which is solid bar a 12mm hole for the rod, and extends an inch into the beam just to take the crush load away on the inner arm weld.
edit: You can just see what I mean on this if your eyesight is good!
