It is currently Mon May 04, 2026 10:36 pm
 Post subject: Rancho trans?
PostPosted: Mon Dec 05, 2011 9:13 pm
K iam in the process of building a new building.From a long break.i want a all round buggy. And i know its going to be hard to get a buggy that will do everything i want and be great at it all..So i have my buggy and i have my motor.Now iam ready to get a tranny.I know bus is the way to go.But like everybody knows they are harder and harder to come buy. there are starting to go for 500 to 700 bucks and thats not counting any mods you want to do.So to the point Rancho pro steet trans.Any good? will it old up to a multi purpose buggy?
 Post subject: Re: Rancho trans?
PostPosted: Mon Dec 05, 2011 9:28 pm
Pretty much a stock car trans with a few goodies, but geared to high for offroad use.
PostPosted: Mon Dec 05, 2011 10:42 pm
so bus is it when it comes to a trans.
PostPosted: Mon Dec 05, 2011 10:52 pm
If your starting fresh i would look at a 1984 and later Vanagon mid shift 6 rib trans and build from there. It offers the strongest reverse VW had to offer.
PostPosted: Mon Dec 05, 2011 11:06 pm
I've never paid over $200 for a fwd trans. The 1st one blew up because I did not weld the spyder gears good.I have a new one in the buggy now with a spare on deck. Hey another plus, no more buying 4 spyder vanagon diffs.How long does a brand new shiny IMA starter last? No oil coolers or external filters with rubber oil lines to blow off.The VR6 has 10 flywheel BOLTS.
PostPosted: Tue Dec 06, 2011 2:46 am
Thanks for the info. I posted a add in the parts section and there are some guys that have a few trans for sale. So I will pick me one up. Then I will go from there.
Iam really wanting to get into racing. Is there places to race?
Where sold I put my money into the trans to make it a stronger more reliable trans?
PostPosted: Tue Dec 06, 2011 8:00 am
The best Trans for your build will really depend on your motor and tires.
What size motor and tires are you planning to run?
PostPosted: Tue Dec 06, 2011 1:21 pm
I would start out with a '84 or newer 6 rib and build from there! There are a few places to race in the mid-west
PostPosted: Tue Dec 06, 2011 4:57 pm
I will be running WC ford 2.0 and as far as tires not sure i was thinking for the woods and trails i would go witha set of 31" cut boggers. and for the street Bf Goodrich tire
PostPosted: Tue Dec 06, 2011 7:36 pm
5 rib with superdiff should be fine. Heck, a 3 rib would work with a 2.0 pretty good.
I've got an adapter and flywheel for that 2.0 if you need it.
PostPosted: Tue Dec 06, 2011 7:54 pm
[quote="shovelhead"]I will be running WC ford 2.0 and as far as tires not sure i was thinking for the woods and trails i would go witha set of 31" cut boggers. and for the street Bf Goodrich tire
I run a Ford 2.3 with a 3 rib and 31" Pro Comp's. Just got my buggy going in the early spring, had it in the woods once and it did pretty damn good. As far as on the street, I tach approx 3000 rpm's running 55 mph. I will eventually build a 6 rib but for now it does good for what I'm doing. As soon as hunting season is over I'll be back to the woods and we'll see how long it lasts from there.
If you're not livin on the edge, you're just taking up too much room !!!
Thanks Maddog i bought the motor and it came with the adaptor plate and flywheel from fearlessclimber on here.
PostPosted: Tue Dec 06, 2011 8:07 pm
84 and newer side shift 4.57. For raceing go to MAORA raceing.us
PostPosted: Tue Dec 06, 2011 8:16 pm
I have been to that site. Just dont understand what class i would be able to run. Not sure where they all race.
Iam wanting to get into some racing just need to get motre info and what not
