It is currently Sun May 03, 2026 11:18 pm
 Post subject: extending frame??
PostPosted: Sat Dec 03, 2011 3:36 pm
how hard would it be to extend the front end of my buggy its a 93 inch wheel base and i was wanting 100 inch wheel base and would it be worth doing or not
 Post subject: Re: extending frame??
PostPosted: Sat Dec 03, 2011 3:46 pm
Are you doing it to keep the nose down? If so it is more of a balencing act then just extending it 10 inches. I would recomend extending it in front of the beam rather then in front. Look at all the single seaters these days, the seats are 12" to 20" in front of the beam.
PostPosted: Sat Dec 03, 2011 5:41 pm
ok thx i was just wanting to make it look alittle better i like the look of the longer buggys but i dont have a problem with it rareing
PostPosted: Sun Dec 04, 2011 12:32 pm
it is fairly easy,jus cut back in different places on top and bottom and get some thick 1 1/4 to slide inside ur frame and make new tubing all the way to front and gusset it up good
