It is currently Sun May 03, 2026 6:48 am
PostPosted: Fri Dec 02, 2011 2:16 pm
I have a dumb question probably about suspension travel in my buggy. I am building a older sandtoys dune buggy and it has a kingpin frontend and only 7 inches between the rails where the tie rods go through. I am wondering if this is going to hinder the suspension travel if I do use a rack and longer arms and such. How much travel will I be limited to?
PostPosted: Fri Dec 02, 2011 7:06 pm
Well you can get a basic idea with some simple algebra.
figure out the length from inner joints to the frame rails. = x
then from the frame rails to the spindle mounts. = y
z= total movement minus some from when it turns.
((y/x)+1)7.5=z
It will give you a rough estimate as long as the neutral position of the trailing arms puts the tie rods in the middle of the frame rails. I think this works, lol.
PostPosted: Fri Dec 02, 2011 9:28 pm
Thanks but I haven't purchased a new beam yet and I was trying to decide between a warrior and dsrace a arm conversion if I couldn't get at least 10 inches of travel.
PostPosted: Fri Dec 02, 2011 10:06 pm
You could always cut out the top or bottom bar and replace it with a curved bar. Or go with a rack from a saturn or grand am that has very wide mounting points. This would allow alot more travel.
PostPosted: Sat Dec 03, 2011 8:36 pm
Brad,
You need to update your location so we can see where you live and what type of riding your are going to do.
If you put a Rack and Pinion, you will get some additional travel and you can also mod the frame to provide more travel.
PostPosted: Sun Dec 04, 2011 1:00 am
yeh its just simple algebra :shock: :shock:
PostPosted: Sun Dec 04, 2011 3:16 am
i think you want to get the angle of the rack rite so theres no bumpsteer, which i might have read somewhere on here :wink:
PostPosted: Mon Dec 05, 2011 1:36 pm
Heres what I did on my woods buggy. Working out great so far! yes I did add more tubing before it was done :mrgreen:
PostPosted: Tue Dec 06, 2011 11:49 am
That looks awesome haven't really thought about doing it that way.
PostPosted: Tue Dec 06, 2011 1:18 pm
I may have used .120 wall DOM for that hoop, but its working out fine so far
