It is currently Mon May 04, 2026 12:34 pm
 Post subject: heads?
PostPosted: Wed Nov 16, 2011 7:00 pm
Hi i was wondering what would be a good set of heads for my motor iam building a 1915 with duel empi 44's. and was wanting to know if a 3 rib bus is a good tranny for that motor thx
 Post subject: Re: heads?
PostPosted: Wed Nov 16, 2011 7:26 pm
044 mags will be an awesome set of heads for that size engine, you can get them at CB Performance, Street Eliminator are killer heads, but it depends on the $$$ you want to spend.
PostPosted: Wed Nov 16, 2011 8:56 pm
i have found a set of 041 heads for 200 would that be a good set up or get something else i don't know what brand they are all it says is 041 heads cut for 94mm jugs
PostPosted: Wed Nov 16, 2011 9:41 pm
3 rib works for 1915.
PostPosted: Wed Nov 16, 2011 10:57 pm
i dont know about heads but on the trans i say 5 rib or side shift
PostPosted: Wed Nov 16, 2011 11:13 pm
buddy i ride with runs 041s..says they got big valves in em, not sure if its a factory thing or what but performs well..may i make a suggestion and ditch the empi carbs. ive never seen a set run good (in the woods) and all ive talked to said webers or dellortos were in the works..jmo
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Wed Nov 16, 2011 11:22 pm
...gotta follow jesse and say 5 rib..3 rib would be fine but with a fresh 1915 i think a 5.38 is a lil slow and would leave you looking for more
PostPosted: Thu Nov 17, 2011 1:15 pm
I LOVE 044 heads, its a nice and not too expensive choice
PostPosted: Thu Nov 17, 2011 6:42 pm
I have to agree with RaceBugg.
You can't beat a set of CB Perf. 044 heads for the money. Great bang for the buck and they hold up well. I would buy a set in a second. They are a great product.
______________________________________________________________
As far as the trans. question, a 3 rib is fine for general use with a small, low hoesepower engine but it will leave you wanting more speed, especially with 31" tires. Try it. See what you think. My experience says that a 5 rib is the best choice for that engine size. You are starting to get into some good power numbers with the 1.9L.
It all depends on the tire size. That directly affects the gearing.
PostPosted: Thu Nov 17, 2011 6:55 pm
ok thx for the reply so the empi's i bought r no good?
PostPosted: Thu Nov 17, 2011 8:22 pm
empis are fine . Going to duel carbs you need to clean the fuel tank even if it is new take the top off the carbs and set the float at 11mm for off road and run good air cleaner . You need to put K-N oil on empi air cleaners and greess on top & bottom of air cleaner. Look for crackes by the spark plug on 041 . They run good on small eng. The 044 wrork good and you can get them with dual spring & 42mm valves . If you build a bigger eng. down the road . Call some of the sponsors like Drews for info on heads cams
PostPosted: Sun Nov 20, 2011 5:19 pm
u all talk about a side shift how hard would that be to make work i though i wild need a nose shift
PostPosted: Mon Nov 21, 2011 8:30 pm
side shifts are great and can find them for around 400 or so or even less from someone that dosent know what they got and someone on here makes a sift linkage i think but the 483 gearing is perfect range for most motors and hey are strong
