It is currently Tue May 05, 2026 1:11 am
 Post subject: Some parts for sale!
PostPosted: Thu Nov 17, 2011 8:06 pm
Muale (87) with brand new rings only maybe an hour on them! $200
Engle 110 also an hour on that! $60
Progressive (weber) with off road air cleaner set up! $200
Set of daul port heads .110 flycut $80
 Post subject: Re: Some parts for sale!
PostPosted: Thu Nov 17, 2011 8:08 pm
Plus 87 have Teflon buttons
PostPosted: Thu Nov 17, 2011 9:23 pm
Also 1.25 rockers with the lash caps only and hour on them $120
Reason for saleing all this is cuz I'm building a 1915 and can't use any of this stuff figured someone was building a motor and could use some good parts!
PostPosted: Fri Nov 18, 2011 3:59 am
dont mean to hijack but i would put the 110 cam and 1.25 rockers on the 1915 if it were mine and nothings wrong with them
then throw on a good set of o44 heads and dual idf webers and you should have a real good running engine jmo.
PostPosted: Fri Nov 18, 2011 8:58 am
x2
PostPosted: Fri Nov 18, 2011 4:54 pm
Going with a vz15 like the way it sounds and proformace is also sweet!
PostPosted: Sat Nov 19, 2011 12:35 am
yeah thats what i have in my 1915 but after climbing with it i wish i had a 110 and 1.25's, the vz15 runs likes crazy from 2000 rpms and up but doesnt like to lug around down low, at least mine dont
PostPosted: Sat Nov 19, 2011 1:04 am
110 is the way to go in this situation
PostPosted: Sat Nov 19, 2011 1:31 am
Go scat c45 love mine!
Don't let out when in doubt!!
PostPosted: Sat Nov 19, 2011 9:46 am
Was going to go with the crower 4? Also but not sure never seen a crower run!
PostPosted: Sat Nov 19, 2011 11:12 am
Crower split duration runs the best in an air cooled VW motor. Especially with dual carbs.
