It is currently Mon May 04, 2026 9:20 pm
 Post subject: pedal assembly
PostPosted: Mon Dec 10, 2007 1:40 am
im looking at these and wounder if they r good quality pedals
http://www2.cip1.com/ProductDetails.asp ... D16%2D2122
PostPosted: Mon Dec 10, 2007 1:43 am
I like independent pedals when the ons made together get old when you mash the brake your clutch will move
PostPosted: Mon Dec 10, 2007 8:25 am
I like the independent pedals also, that way you have more adjustment. The roller gas feed is not any good either. Get one with a regular gas pedal.
PostPosted: Mon Dec 10, 2007 9:36 am
I have not had an issue with the clutch moving when pushing the brake however I have had the roller gas pedal move when pushing the brake. Thats not a good thing. I seperated the gas peda from the assembly and went with the flat plate pedal style. A much better set up. If you go with the combo set up install a grease fitting in the casting where the shaft rides and keep it lubed and it will work for a long time and not have one pedal moving the other. I would still run a seperate gas pedal.
PostPosted: Mon Dec 10, 2007 11:36 am
Actually this is a better set up and cheaper. It's better because it uses an aluminum mounting bracket instead of the chrome one in the other pic.
http://www2.cip1.com/ProductDetails.asp ... D16%2D2133
PostPosted: Mon Dec 10, 2007 4:43 pm
this is better dual cylinders baise adjustment ect... :)
http://www.speedwaymotors.com/p/7192,17 ... Mount.html
this works well to :)
http://www.speedwaymotors.com/p/7069,17 ... Mount.html
PostPosted: Mon Dec 10, 2007 6:14 pm
IMHO those cheaper imported brake systems are just a heartbeat away from letting your buggy smash into a tree.
Been there, seen that happen.
That crap on the CIP1 link about CNC etc taking only American fitting is BS too.
I order all my CNC stock with metric fittings.
Cry once and buy the good stuff:
http://www.cncbrakes.com/
PostPosted: Mon Dec 10, 2007 8:58 pm
that's wright turbo
PostPosted: Mon Dec 10, 2007 11:15 pm
If you do end up with a pedal set that is has American fittings you can always buy the adapters. Most circle track supply houses carry them. The Chassis Shop is one I know off the top of my head that has them.
John
PostPosted: Mon Dec 10, 2007 11:52 pm
I plumdeb my brake/clutch with jic -4 fittings and line it worked sweet :D
PostPosted: Tue Dec 11, 2007 1:00 am
I run the CNC pedals, they are seperate and you can mount them any way you want. They are the CNC series 254C with a tall style rectangular reservoir. They work great!!
