It is currently Tue May 05, 2026 12:46 am
 Post subject: Bending tube
PostPosted: Sat Nov 05, 2011 4:42 pm
I was wondering if any one has ever used one of these www.affordablebender.com The price is right but I do not want to spend money on this and then have to buy a JD2 in three months. The only problem I see is it does not bend past a 90. Thanks for any input
 Post subject: Re: Bending tube
PostPosted: Sat Nov 05, 2011 4:47 pm
we used one of those to build a few buggys and it worked fine . just like you say it doesnt bend past 90 degree is the bad.
PostPosted: Sat Nov 05, 2011 7:21 pm
The price is right.. It sure would be handy to be able to bend tubes in the garage. I am not sure about an entire frame but for a few random pieces, it would be great.
PostPosted: Sat Nov 05, 2011 7:36 pm
that is the same tube bender that i copied, I used an enterpack cylinder with a air overhydrolic pump. I have built alot of cages from race car to full jeep roll cages and buggy frames. I have no problem with the machine not bending over 90 degrees. you will be able to use that for anything you need.
PostPosted: Mon Nov 07, 2011 6:01 pm
I have used afterburnts and it works great very simple to use also !
PostPosted: Mon Nov 07, 2011 11:44 pm
I would say...BUY IT!
PostPosted: Tue Nov 08, 2011 1:02 pm
not bad but you can just about buy a jd2 for that.
PostPosted: Tue Nov 08, 2011 1:06 pm
http://www.ebay.com/itm/JD2-Model-3-Ben ... 415f184a85
http://www.ebay.com/itm/1-1-2-ROUND-TUB ... 45fcfea52e
now you can bend 180*
PostPosted: Tue Nov 08, 2011 1:19 pm
http://tubetek.net/products/product_details.php?p=7
Look at this site also, I think I had around $400 in it by the time I added air over hydrolic ram. Works great!
