It is currently Mon May 04, 2026 8:57 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 Post subject: Mommy not again.... :(
PostPosted: Sat Oct 15, 2011 12:31 am
Sob....
PostPosted: Sat Oct 15, 2011 5:02 am
i gess your not going to camp this weekend ?
PostPosted: Sat Oct 15, 2011 5:36 am
Wowzers !
PostPosted: Sat Oct 15, 2011 11:28 am
that's a big oucheee!!! see ya next year.
- Sigmund Freud
- Antonio Meloni
PostPosted: Sat Oct 15, 2011 12:51 pm
And you guys wonder why I'm tired of VW, lol. Didnt drive 9 hours to do that did you?
PostPosted: Sat Oct 15, 2011 11:01 pm
Had a spare 6 rib. On my way back from Wellsville now. I was 2nd gear climbing with the spare.
PostPosted: Sun Oct 16, 2011 1:36 am
Thank god its just the ring gear. The pinion looks fine.
PostPosted: Sun Oct 16, 2011 7:20 pm
Ring & pinion are mached sets + I bet pinion is crack.
PostPosted: Sun Oct 16, 2011 11:44 pm
Something is VERY wrong in that trans for it to only break the top edge of those teeth off like that. Better take it all the way down and inspect everything real close.
PostPosted: Mon Oct 17, 2011 12:20 am
Yes something is way off!
PostPosted: Mon Oct 17, 2011 1:44 am
i would say the backlash was not set right and the pinion was not deep enuff in the ring gear
PostPosted: Mon Oct 17, 2011 9:51 am
I was wondering the same thing. I wonder if the pinion nut loosened up. I was climbing a hill and couldn't get over a rock. I backed up and it was stuck in reverse. Would go about 20' then stall the buggy. I got it to the bottom of the hill and it came out of reverse. I put it in first and it got stuck again, drove it about 1/4 mile and everything went back to normal.
PostPosted: Mon Oct 17, 2011 12:10 pm
Somethings moving around. Is the pinion bearing ok?
PostPosted: Mon Oct 17, 2011 12:58 pm
Don't know. I have to get my trans tools to pull the diff and see.
PostPosted: Mon Oct 17, 2011 1:29 pm
insert hillaholic joke here
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Oct 18, 2011 1:45 am
I've seen bad pinion brg let pinion move in and out 1/4" or better and that would also cause havoc with forward and rev like pop out jam up etc and that would also explain the shallow gear pattern on the ring gear
Nice 1 Bill lol
PostPosted: Fri Oct 21, 2011 2:36 pm
OUCH :|
PostPosted: Tue Oct 25, 2011 12:52 pm
Time for another rebuild. I can move the pinion 1/4" in and out.
PostPosted: Tue Oct 25, 2011 7:47 pm
bring it down to Brian.
PostPosted: Tue Oct 25, 2011 8:31 pm
Time for a new case. The bearing should fit in that bore TIGHT. You should actually have to heat the case to make it slide together.
PostPosted: Wed Oct 26, 2011 1:47 am
Just as I pictured it pinion brg shot,Aaron I had one that the race was tight in case but the brg itself was junk
PostPosted: Wed Oct 26, 2011 10:12 am
Ocassionally, it's a good idea to feel for movement in your shifter, while accelerating and then letting off, if the shifter tries to move by itself, it's an indication of imminent pinion bearing or nut failure.
PostPosted: Wed Oct 26, 2011 11:13 am
The nut came loose. It took no effort to loosen it. I don't have my book but isn't the nut supposed to be torqued to 198# or something? Also I tightened the nut to at least 100# and the pinion still moves. The nut and bearing don't move just the pinion.
PostPosted: Wed Oct 26, 2011 1:31 pm
After you remove the pinion and bearing,check for pinion bearing fit in the case, I'd bet that pinion bearing spun in the case.
I usually check pinion bearings by clamping them in a vise, and if I can feel any pinion shaft movement from side to side at all, it gets replaced.
Also I prefer good used german bearing over a new fag brazil one.
I torque them to around 200# and always use blue locktite.
PostPosted: Wed Oct 26, 2011 7:42 pm
do NOT buy FAG bearings. They are part of the group I work for, they are junk. When I worked at Timken I used to test them. JUNK.
