It is currently Sun May 03, 2026 10:51 pm
 Post subject: problem!!!
PostPosted: Sat Oct 15, 2011 8:00 pm
Bought a motor and put the heads on it and it pumps oil but the push rods aren't moving!!!!! Any ideas guys???
 Post subject: Re: problem!!!
PostPosted: Sat Oct 15, 2011 8:20 pm
This should be an obviously visible problem,but need more info. How do you know the motor is pumping oil? What size motor,etc.
PostPosted: Sat Oct 15, 2011 8:21 pm
Lifters or a cam in their lol :wink:
PostPosted: Sat Oct 15, 2011 9:40 pm
Yes cam and lifters r in it its all stock.
PostPosted: Sat Oct 15, 2011 10:48 pm
cam gear might be broke .take out oil pump and look see if cam gear is moving .if so and it should be if oiling cam is broke?
PostPosted: Sun Oct 16, 2011 4:15 pm
cam has to turn to have oil pressure. at least the end of it that bolts to gear. sounds like maybe cam is broke. idk but whatever it is its not good tear it apart!!! :roll:
PostPosted: Sun Oct 16, 2011 6:52 pm
Cams broke!
PostPosted: Sun Oct 16, 2011 7:11 pm
jackson.ryan29 wrote:
Cams broke!
next ?? it why
PostPosted: Tue Oct 18, 2011 8:51 pm
poor oiling or bad cam bearing .rebuild it and be done with it.
PostPosted: Thu Nov 17, 2011 11:14 pm
Bad cam!
