It is currently Mon May 04, 2026 3:39 pm
 Post subject: Removing studs?
PostPosted: Thu Oct 13, 2011 9:35 pm
Need to remove case studs so I can put longer ones in for my six rib bell
Seems like they could be pretty tuff to get out
Was planning on pb blasting em and and double nutting em seems to be obvious way to do it
Any tips or tricks would be appreciated
IF IT AINT BROKE FIX IT TILL IT IS;)
 Post subject: Re: Removing studs?
PostPosted: Thu Oct 13, 2011 11:07 pm
You have the right idea. They normally don't come out too hard. Be sure to put some loctite on the longer ones when you reinstall them or they will likely come out everytime you pull the engine.
PostPosted: Fri Oct 14, 2011 1:56 am
these work good too.
http://images.search.yahoo.com/images/v ... .RQA81wBzH
PostPosted: Fri Oct 14, 2011 4:09 am
my suggestion also
