It is currently Mon May 04, 2026 12:18 pm
 Post subject: cv degree ??
PostPosted: Sun Jul 24, 2011 10:21 pm
setting my suspension up now and was wonder what u guys were having luck with on the cv angle ?
i have it set at 14 degree now and just want to make sure there is nothing im missing before i do my suspension mods .
specs
2x3 arms
bus cvs clocked
18 3/4 axles
thanks for any help
jason
 Post subject: Re: cv degree ??
PostPosted: Sun Jul 24, 2011 10:27 pm
14 degrees is a little low.. You can probably go a bit higher.. I run 18 degrees at ride hight and 20 degrees at full droop..
PostPosted: Sun Jul 24, 2011 11:46 pm
Are they type 2 or 4 cv's?
PostPosted: Mon Jul 25, 2011 1:13 am
how can you tell the difference, i know the type 4 is supposed to have more travel but when i ask for them at the local buggy and foreign car stores they tell me they are the sme as bus joints?????????
PostPosted: Mon Jul 25, 2011 7:42 am
type 4 are 2mm thicker.... this info is from blinkchickens site i assume these degrees are with stock cages Type 1 is 12 degrees
Type 2 is 17 degrees
Type 4 is 22 degrees
930 is 25 degrees
PostPosted: Mon Jul 25, 2011 7:47 am
im not sure if their 2 or 4 brad ,sorry
rick , is those angles max angles or were you set your buggy at sitting ?
thanks guys
PostPosted: Mon Jul 25, 2011 2:10 pm
this is from there page, Maximum Angularity for each CV is listed below
PostPosted: Mon Jul 25, 2011 2:50 pm
There is a bunch more to all this than just some number assigned to a particular CV. I would Maybe use this number as a starting point to get thing set up. Unless the chassis (rear torsion housing) is dead level and the trans drive flanges are exactly perpendicular to the housing those numbers mean nothing.
PostPosted: Mon Jul 25, 2011 5:57 pm
exactly what mike said.i tweeked on my rear suspension for a long time before i got everything to work right but now i run my type 2s at 19 deg and never have any probs.what you really need to check is your rear alignment (camber)at ride height.you may have good angle on your inner cv but if your arms are bent or not built right youll be maxing out you outer cv but your axle angle could still be good.ive seen alot of aftermarket arms built wrong or with bent cups and the guys cant figure out why they blow outer cvs or they click even with limit straps.everones seen that orange suby buggy with 4" of rear ground clearance and clicking cvs .
PostPosted: Mon Jul 25, 2011 6:01 pm
Josh, are you talking about that orange one that never makes it up any hills, and the wheels always fall off of??
PostPosted: Mon Jul 25, 2011 6:45 pm
you must of seen it too!
PostPosted: Mon Jul 25, 2011 6:49 pm
i think they call him the lumberjack or something like that cause he's always cutting down trees to get back down the hills.
PostPosted: Mon Jul 25, 2011 11:12 pm
I heard that he tried to climb a hill over at Lookout, and that is why it looks the way it does now.... Can anyone confirm this?
PostPosted: Sun Jul 31, 2011 12:59 pm
What's with all the references to last year- I don't have any clearance or cv issues this year. Dickheads.
PostPosted: Sun Jul 31, 2011 7:04 pm
If you cant grab the axle and move it back and forth between the trans and stub axles with the rear tires jacked up off the ground the cv will not stay together no matter what kind it is . My axles angle back so i couldnt set them to the angle of a bus joint " max angle" so I jacked mine up and drew the swing arm up with the limit strap until I had about 1/2 inch movement in my axles .
PostPosted: Sun Jul 31, 2011 9:05 pm
aboone993 wrote:
mine have 1/2" slack with the limit straps tight but still click,,,is this normal?
I hope so because thats exactly how mine are.
