It is currently Mon May 04, 2026 11:21 am
PostPosted: Fri Jul 08, 2011 2:17 pm
Trying to figure out what I have for Clutch and other parts in case I need to replace some day. Figure I might as well look while I have it appart.
PostPosted: Fri Jul 08, 2011 3:59 pm
what in the world are you talking about lol
PostPosted: Fri Jul 08, 2011 7:11 pm
The clutch or pressure plate or whatever the heck else is in the bellhousing, lol. What, I wasn't clear? :roll:
PostPosted: Fri Jul 08, 2011 8:17 pm
Are you going to show pics or should we start guessing? :) :shock: :) :) :lol:
PostPosted: Fri Jul 08, 2011 10:25 pm
Fine, had to dig out my camera :roll:
PostPosted: Sat Jul 09, 2011 4:34 am
thats an "early" style vw throwout bearing but im not 100% on what the pressure plate is but it kinda looks to be vw also and so does the flywheel from whats visible in the pics and if so i would guess the clutch disk is vw too
PostPosted: Sat Jul 09, 2011 9:15 am
I know its VW but it is a ton stiffer then my 3 ribs clutch. Bout all I know.
PostPosted: Sat Jul 09, 2011 9:48 am
most likely a kennedy pressure plate dose it have a stage two or stage II marked on it some where ? could be a 228 mm or most likely a 200 mm clutch . Now is the time to ck your disc while you are apart .
PostPosted: Sat Jul 09, 2011 10:36 am
So how do I check my disk?
PostPosted: Sat Jul 09, 2011 3:28 pm
Just take the 6 bolts off around the outside of the pressure plate and the pressure plate and disc will fall off the fly wheel.
PostPosted: Sat Jul 09, 2011 4:23 pm
also make sure to make note of which side of the clutch disk faces the flywheel and which side faces the pressure plate because the center hub on the clutch disk is flat on one side and is raised on the other
PostPosted: Sat Jul 09, 2011 4:43 pm
a disc can only go in one way no way to mess that one up .....i think
PostPosted: Sat Jul 09, 2011 5:45 pm
It is a good idea to replace your pressure plate bolts,,and careful torquing them,,,dont take much.
PostPosted: Sat Jul 09, 2011 8:50 pm
No torque wrench yet and it seems to be working good so far. At this rate the tranny should blow again by the time I need to swap it, lol. Gotta get away from these VW parts. Tired of fixing them. Just waiting on my first GM part to fail so the VW stuff don't feel so bad, lmao.
