It is currently Mon May 04, 2026 4:27 am
Post new topic Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Jun 25, 2011 2:19 am
Bump steer was horible, wish I knew of it when I made the GM box Mod.
So I decided to center the box and switch to heim joints.
A little help from a new drill press and Notcher
PostPosted: Sat Jun 25, 2011 2:24 am
Had to make the tappered holes smaller to fit the 5/8 bolt on the heims.
Much closer to the beam and in the center now. Should rmove most of my bump steer.
Little rattle can magic !!!
PostPosted: Sat Jun 25, 2011 8:57 am
Lots of nice work. Nice buggy all around. Where did you get that switch panel?
PostPosted: Sat Jun 25, 2011 10:01 am
Either Speedway or Jegs. And Thanks.
PostPosted: Sat Jun 25, 2011 3:31 pm
you made a lot of progress in a few hours :wink:
PostPosted: Sat Jun 25, 2011 10:07 pm
My tie rods are an inch too long, fffffuuuuuuu!@#$#@!@##!!!!!
4" difference from front of tire to rear!
But I did get the steering shaft done today and painted.
PostPosted: Sat Jun 25, 2011 10:13 pm
Well I was in the garage untill 2:30 last night then back in it at 10am this morning till 9pm. But I did watch alot of WWII in color too :roll:
PostPosted: Mon Jun 27, 2011 5:55 pm
Did you cut it an inch when you gave me the measurement?............... :lol:
PostPosted: Mon Jun 27, 2011 6:31 pm
I wrote down 18-3/4, but not 100% certain that is what I told you. :roll: Chopped an inch off of one and it works.
PostPosted: Tue Jun 28, 2011 10:24 am
19-3/4" is what you gave me, still have the note............ :mrgreen:
All good now?
Those babies ought to take a pretty good hit.......... 8)
PostPosted: Tue Jun 28, 2011 12:45 pm
Yep I am good to go, easy fix. And I can't see those bending, lol.
PostPosted: Tue Jun 28, 2011 2:07 pm
Knock on wood... quick...quick...
PostPosted: Tue Jun 28, 2011 4:27 pm
1-1/8 or 1-1/4 solid alum with 3/4 heims. The chevy box is now the week link, lol.
PostPosted: Tue Jun 28, 2011 5:20 pm
ill bet that caption morgan will bend them :lol:
PostPosted: Tue Jun 28, 2011 10:29 pm
Hopefully someone will bring me some apple pie in a jar this weekend to give the new front end a good testing :twisted: :twisted: :twisted:
Plumbed my new front breaks this afternoon. Took about 15 minutes for me to bleed them out with the power bleeder, gotta feeling they will need a bit more once I run it a bit. Tried it on the street real quick and it stopped on a dime, loved it.
PostPosted: Mon Jan 23, 2012 12:03 am
Ok few mods. Added a dual res brake setup so if i loose a line i still have some brakes, and a new gas pedal. Hated the wheeled one.
And I re-did my steering box mount. Snapped the other one off when i crossed a big ditch and got hung up.
PostPosted: Sat Mar 31, 2012 11:00 am
Bump for AndrewHA
PostPosted: Sat Mar 31, 2012 3:09 pm
I put that same pedal in mine and the only thing I found I don't like is if a little piece of gravel or stick or anything gets under it while you got it down it won't let the pedal return and sticks the throttle.I was going to raise mine up off the floor a little bit with a spacer.just thought I'd tell you. Chad :mrgreen:
PostPosted: Sat Mar 31, 2012 6:05 pm
Thanks Chad, good to know
PostPosted: Mon Apr 30, 2012 5:07 pm
Well here was the latest hickup in the upgrade process.
So i started building the new rear cage
And man are tabs hard to weld for the skidplate with the engine in, lol.
PostPosted: Mon Apr 30, 2012 7:12 pm
is that header empi?? :lol: :lol:
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Mon Apr 30, 2012 7:17 pm
Might want to put something in front of your pulley in case say someone has been in the jar all night and doesn't decide to stop when you stop and hits your motor,lol.just saying. Chad :mrgreen:
PostPosted: Mon Apr 30, 2012 8:59 pm
Soooo what you are saying is I need to follow you? lol
PostPosted: Tue May 01, 2012 7:22 am
Lol, stock exhaust manifold, but might be an empi stinger :roll:
PostPosted: Tue May 01, 2012 7:24 am
Thanks, the switch is an ARC8000 and I love it. I know a few other guys run them too. They make a 4, 8 and I think 12 switch panel.
