It is currently Mon May 04, 2026 5:42 am
 Post subject: Ball & Socket
PostPosted: Tue Jun 07, 2011 1:10 pm
Where can i find a ball and socket setup like the one weddle uses in their linkage.
I've looked online and cant seem to find exactly what im looking for.
IF IT AINT BROKE FIX IT TILL IT IS;)
 Post subject: Re: Ball & Socket
PostPosted: Tue Jun 07, 2011 2:09 pm
i used the ball out of one of these and used a 1/2 inch socket for the socket just had to hone it out a bit.
http://cgi.ebay.com/Ball-Joint-Tie-Rod- ... 20b6459196
PostPosted: Tue Jun 07, 2011 3:34 pm
How about something like this. They are avalable in 3/8" and 1/2":
http://cgi.ebay.com/ebaymotors/NEIKO-3- ... veQ5fTools
Heres a pair of them 1 - 3/8" and 1 - 1/2":
http://cgi.ebay.com/ebaymotors/2Pc-3-8- ... 3368580e51
PostPosted: Tue Jun 07, 2011 3:51 pm
hadnt thought of using either of those items.GENIUS!!!! 8)
PostPosted: Tue Jun 07, 2011 8:06 pm
Your welcome.
PostPosted: Wed Jun 08, 2011 9:37 am
Just a thought on the Impact style setup. You will need to drive the anti spin pin out so you have full articulation. Not sure if there is one or actually how they keep it fronm spinning however food for thought. I have not seen these to accertain.
PostPosted: Thu Jun 09, 2011 12:38 am
i used a ball from a tierod end and a piece of 1 1/4 tube wit a brass bushing
PostPosted: Mon Dec 03, 2012 2:12 pm
? i thought about this and you know what you dont need a "ball an socket" joint just a heim joint. weld the spud round rod to the transmision piece make it unersized so it slips in the ball of you heim joint the put the heim joint on the arm horizontal coming in from the back that way youve done the same thing! Keep the center of the ball about the same place as it would be with the ball an sockt joint and its done. 8)
