It is currently Sun May 03, 2026 4:27 am
 Post subject: Won't start.
PostPosted: Mon May 16, 2011 6:27 pm
Sat. Night my starter gave up. So I thought. First it seemed to need to cool down, and then it would start. Then/now it won't do anything. I got a new starter and it won't even click. I used a test light and my switch is sending it power. ??? I don't know. Any Idea.
 Post subject: Re: Won't start.
PostPosted: Mon May 16, 2011 6:42 pm
so you have power from the switch. you positive you have power from the bat too? if so that starters no good ether. ive had it happen too before.
PostPosted: Mon May 16, 2011 6:51 pm
Just a maybe. Never paint the surface where the trans and the starter meet.Will not have a good ground.
PostPosted: Mon May 16, 2011 7:08 pm
My buddies did that when the brass bushing was bad.
PostPosted: Mon May 16, 2011 8:11 pm
I'll have to look at that.
PostPosted: Mon May 16, 2011 10:08 pm
will the engine turn over by hand. I had an engine get hydro-locked by gas. I pulled all the plugs and was able to clear the cylinders out. Found out i had abad needle and seat and caused at least two cylinders to fill up with gas. :oops: Just something else to look at.
I know your buggy is newer too. Just make sure that your battery cables are good and tight and that where they attach to your frame that it is a good clean connection.
PostPosted: Tue May 17, 2011 6:43 pm
Mine did something similar.. After 3 starters, I figured the starter was not the problem.. The starter would turn over by itself but would do nothing with engine installed..
Turned out of be a bad ground on my battery.. Check your grounds really well..
PostPosted: Mon May 23, 2011 1:02 pm
1 dead cell in your battery and you'll loose nearly 1/2 your cranking power.
PostPosted: Wed May 25, 2011 11:06 pm
Now i have installed, re-installed 3 starters like 100 times, checked my wires, ground some more paint off to make sure I have a good ground, replaced to starter bushing, new fuse box, cried, drank, and still can't get it to crank.
With the new starter, the the paper work said it will not hurt the starter if you hooked the starter wire to the wrong post so I tried this too. I will throw the starter gear out but no spin. Anything I could be missing :cry:
PostPosted: Wed May 25, 2011 11:42 pm
can you turn the engine over by hand? sounds like something else to me.
PostPosted: Thu May 26, 2011 8:06 am
Yes.
PostPosted: Thu May 26, 2011 8:35 am
sounds to me like on of ur main battery leads r bad or broken my buddy thought he had a bad starter one time and he for got the main hot wire to the starter from the battery it acted just like urs is
PostPosted: Thu May 26, 2011 12:40 pm
Cables look good, put new end on pos @ the battery, by passed the battery cut off. All power seem fine, lights, fuel pump etc... I disconnected all accessoies and except the starter and same thing. As soon as I hit the starter button (i've by passed it and tried using straight wire in case bad switch) it sounds like it throws the gear out and thats it. Could it some how ground itself out or something? This seems like it should be so simple. I did try all 3 starters I have on a spare bell housing and they all spin fine.
PostPosted: Thu May 26, 2011 2:26 pm
i have tried jumping the starter straight from bat, and from a jumper pack with nothing else hooked up. same result.
PostPosted: Thu May 26, 2011 3:50 pm
You need to check your amp load on your starter when its trying to turn. If you dont have an amp probe, turn on all your lights and see if they dim when its trying to spin. if yes, then everything sounds good on the electric side. I think the starter should pull no more than 80 amps, but more like 50 amps. Have you tried roll-starting it? maybe a stupid question, but are you sure you have the correct starter/bell housing combo?
PostPosted: Thu May 26, 2011 7:07 pm
Once I had a block align bored so bad it had several tight spots and it made me think I had unreal compression.It was so bad the flywheel was very tite against the bellhousing scrubbing out the aluminium.
PostPosted: Fri May 27, 2011 12:12 am
:D :D :D :D :D
After long hours of trading starters, testing, and chasing wires its alive. My battery wasn't caring any load. The volts were good though. It seems to all have been caused by a bad Alt wire.
Thanks everyone for your input. I have now done a very good 10 times over of my wiring(on the bright side). Now I'll be leaving to ride in the morning!
