It is currently Tue May 05, 2026 12:52 am
 Post subject: Wont idle
PostPosted: Tue May 24, 2011 10:48 am
Got a stock motor, it turns over and runs good for about 20sec and then cuts out. It idled fine about 3 weeks before i started wiring it up , setting up throttle cable and everthing. It also sat outside, but had a tarp over it, if that means anything. any clues what to check? thanks
 Post subject: Re: Wont idle
PostPosted: Tue May 24, 2011 12:20 pm
Id say just give the carb a goood once over and see where your at after that.
"IT IS WHAT IT IS"
PostPosted: Tue May 24, 2011 6:29 pm
If it is a stock solex take that gold anti dieseling valve off the side and clip the copper wire off or plug it off with a bolt.Past that, look for intake leaks.
cron
