It is currently Mon May 04, 2026 9:17 pm
PostPosted: Mon May 16, 2011 9:29 pm
http://www.pirate4x4.com/articles/tech/ ... ummer_Rims
saw these on pirate... the guy who makes them says he can make them in any lug pattern including 4lug vw..... what do you guys think about internal dual beadlocks like these?
if it aint broke don't fix it
PostPosted: Tue May 17, 2011 6:28 am
I can't see the pictures?? :?: :?
PostPosted: Tue May 17, 2011 8:11 am
I ilke beadlocks for 2 reasons. They keep the tire on the wheel, AND they protect the wheel from bending. you loose that with an internal beadlock... and chicks dont see internal beadlocks :lol:
PostPosted: Tue May 17, 2011 8:58 am
Tires are more expensive for a 16.5 wheel and they will be heavier due to being a 3/4 to 1 ton application
IF IT AINT BROKE FIX IT TILL IT IS;)
PostPosted: Tue May 17, 2011 9:57 am
they are two piece internal beadlocks.... the ones on that page are the originals... now they make 15 inch any bolt pattern(including vw) with a lighter internal piece...locking both the inner and outer bead by pinching them against the internalpiece as the two halves are tightened together....
http://i259.photobucket.com/albums/hh28 ... adlock.jpg
this version is made any size or lug pattern not just the military rim remanufactured. and weight of vehicle will not change weight of rim unless its a semi... same rims unless they are dually rims on all 1/4, 1/2,3/4,and 1 ton trucks... only diff between them is lug pattern and sometimes not even that
http://www.pirate4x4.com/forum/showthread.php?t=979610
here is the new version which is not just reusing military hummer wheels
http://i259.photobucket.com/albums/hh28 ... dlock2.png
maybe someone on here could cut an aluminum rim in half and add centers like they have done in the new version to save weight
PostPosted: Tue May 17, 2011 10:03 am
thats what the rebar rock ring is for..... and internal beadlocks should work on the chicks..i mean they believe it when you tell them you will pull out :shock: so why wouldnt they believe you have an invisible beadlock
PostPosted: Tue May 17, 2011 10:37 am
I'm bidding on a set of 15" combat rims at the moment which are constructed in exactly the same way.. except they're from 1957!
