It is currently Mon May 04, 2026 10:37 pm
 Post subject: Popping out the exhaust
PostPosted: Wed May 11, 2011 9:36 pm
put a turbo on my buggy over the winter and rebuilt the carbs and now I have some random popping out the exhaust, engine is 74x94 (2054)cc with a T3 .42/.48 turbo and dual 44 idfs with F11 emulsion tubes, 185 air jets, 160 mains, 60 idle and 65 pump jets. 0 bypass, 24 degrees total timing recommended for turbo, electric fuel pump with boost sensitive pressure regulator set at 3.5 to 4 psi and currently running bosch platnium plugs but going to change to a colder heat range like a NGK b8s car runs good,idles fine just pops out the exhaust hot cold does"nt matter anyone have any ideas? :?:
PostPosted: Wed May 11, 2011 10:24 pm
post it here and im sure someone will be able to help you 8)
http://www.shoptalkforums.com/viewforum ... 79f985f394
PostPosted: Wed May 11, 2011 10:45 pm
thanks Bluebuggy I"ll give it a try
PostPosted: Thu May 12, 2011 8:07 am
Sounds like you got a plugged up idle jet or in the idle circuits.
PostPosted: Thu May 12, 2011 8:10 am
Lean condition.
PostPosted: Thu May 12, 2011 10:54 pm
Is this just at idle or under load?
PostPosted: Fri May 13, 2011 1:25 pm
mostly at idle is not real consistant though justs pops now and then
PostPosted: Fri May 13, 2011 1:31 pm
Clean out idle jets.
PostPosted: Fri May 13, 2011 6:30 pm
leaking exaust gasket? Ex valve adjusted too too tight?
