It is currently Mon May 04, 2026 11:09 am
 Post subject: Steering Dampner
PostPosted: Sun May 08, 2011 8:57 am
What are you guys using for your steeering dampner? I use to always run a bus steering dampner but if I am going to buy a new one I might as well see what else is recommended. I'll be putting it on a Saco rack with charlynn hooked up. Thanks, Adam.
 Post subject: Re: Steering Dampner
PostPosted: Sun May 08, 2011 9:03 am
the rack with Charlynn is the best steering dampner I have discovered, If you mount the inner tie rods as close to the beams as possible you wont need any thing else with the Charlynn.
PostPosted: Sun May 08, 2011 5:22 pm
I certainly don't feel the need for one, but seem the think it would however take a little of the beating.
PostPosted: Sun May 08, 2011 6:43 pm
if you have the tie rod ends properly located there will be minimal feedback and bumpsteer and the charlynn acts like the worlds best steering dampner
