It is currently Sun May 03, 2026 6:20 pm
PostPosted: Mon May 02, 2011 9:30 pm
shot in the dark but figured i would ask you guys . light green/ black f47 plug # 23 which is ground for fuel pump relay has a constant flash , i have other issues but im going to go step by step on this !
i figure i would start here because i am clueless on a ground sending ground pulse !
thanks for any help .
Jason
PostPosted: Mon May 02, 2011 10:14 pm
start with buying my subaru for $3000 lol i need mine gone
*subiepower*
PostPosted: Mon May 02, 2011 10:30 pm
Jason
pm rail 1914, he helped me a ton and has endless info on the suby wireing!!! and if he caint help the guys at engine wireing.com have always been free with advice every time ive called.
lets just ride
PostPosted: Tue May 03, 2011 1:52 pm
http://www.cannell.co.uk/Subaru_Worksho ... mpreza.pdf
lot of info here..
"I got this..."
PostPosted: Wed May 04, 2011 8:55 am
I'm pretty sure the fuel pump relay has a constant 12v going to it and the computer grounds the relay when it need to run the fuel pump. That is why you are seeing the pulse on the ground wire.
PostPosted: Wed May 04, 2011 10:47 am
that sound rite... ill get you all the wiring diagrams tonite, those should help you out...
PostPosted: Wed May 04, 2011 11:00 am
Big Scott is right. Constant 12v to relay, computer grounds relay, pump operates. Don't try to read too much into this stuff, it's not that complicated.
PostPosted: Wed May 04, 2011 10:23 pm
did u get the main relay working ??? u need it first
PostPosted: Thu May 05, 2011 7:40 am
no work on wiring last night i took a break and worked on oil filter relocator , but main relay is getting worked on tonight !
thanks for the imput so far guys !
jason
