It is currently Mon May 04, 2026 1:36 pm
PostPosted: Sat Mar 26, 2011 9:39 pm
Whats the word on an 81 side shift... good/bad?
PostPosted: Sat Mar 26, 2011 9:47 pm
thicker ribs makes the case better,,makes a stronger , less likely to flex,,,convertible to nose cone shift makes it great for parts,,not as beefy gears as the "mid shift". Might be 4.57,,,4.86 or 4.83,,,might have super diff,,but rare. Get it cheap as you can and save it. jmo
PostPosted: Sat Mar 26, 2011 9:52 pm
That was nice and quick :D Thanks firebug.
PostPosted: Sat Mar 26, 2011 9:57 pm
I sure aint no expert but those are my thoughts,,,good luck
PostPosted: Thu Apr 07, 2011 8:31 pm
I am running one that i had converted for nose shift. Running it behind a v-8 chevy. so far so good
PostPosted: Fri Apr 08, 2011 3:17 am
Here's a chart of the gear ratios depending on transmission code. I think all Vanagon transmissions are listed.
http://www.syncro.org/FinalDriveRatios.htm
MG
PostPosted: Mon Apr 11, 2011 8:30 am
its basically the same as a 6-rib. From Gary?
PostPosted: Wed Apr 27, 2011 8:35 am
What does it take to convert one to a nose shift?
I get to Climax every night.
PostPosted: Wed Apr 27, 2011 11:17 am
you have to change mid section and nose cone...
Don't let out when in doubt!!
PostPosted: Thu Apr 28, 2011 8:15 am
Can you use a three rib for those parts?
PostPosted: Thu Apr 28, 2011 5:36 pm
no the mid section is a little shorther and i think the rails wont match...?
