It is currently Tue May 05, 2026 1:15 am
 Post subject: Dual Carb question
PostPosted: Tue Apr 26, 2011 8:14 pm
Finally got these webers working, Got them synced adjusted idle mixtures to the best of my ability (first timer) with these carbs lol. But when its juss sittin there idling and ya crack the throttle it sounds great doesnt skip a beat. Where Im noticing a problem is take off, Example- I wound it up a little in the driveway and dumped it and it seemed like it had a dead/flat spot there, Then once ya got going It came on and pulled good kinda set ya back in the seat, Can tell major difference in torque when putting along and tap the throttle. But Any Ideas as to what would solve the problem im having? or maybe im juss not adjusted right? I was thinking maybe i need to play with the accelerator pumps?
"IT IS WHAT IT IS"
 Post subject: Re: Dual Carb question
PostPosted: Tue Apr 26, 2011 8:25 pm
Get a HOLLEY !!!! LOL
Accel pumps is where I'de start
PostPosted: Tue Apr 26, 2011 8:29 pm
Take that Holley crap and stick it right up your _________!!!! Your decide where!! LMAO :mrgreen: :mrgreen: Thanks DVS1 , the plugs are almost a golden brown so the jetting has got to be right, atleast IMO, Guess ill mess with those tomorro see if it helps.
"IT IS WHAT IT IS"
PostPosted: Tue Apr 26, 2011 8:40 pm
X2
PostPosted: Wed Apr 27, 2011 7:46 am
i heard u was waiting on that so i threw it out there
PostPosted: Wed Apr 27, 2011 8:38 am
lol....Yea I have such nice friends!! Dave and tonya have been bustin my ass left and right over these haha. All in good fun though :mrgreen:
"IT IS WHAT IT IS"
PostPosted: Wed Apr 27, 2011 8:42 am
I think What I will do if I dont get everything just right is Buy an extra case of beer, take $20 with me and Have someone show me what Im doing wrong lol
"IT IS WHAT IT IS"
PostPosted: Wed Apr 27, 2011 9:41 am
What size motor, Idel jets, main jets and air jets are you using. Also how many turns are your mixture screws out. If they need to be past 2 turns to Idel then increase the Idel jets a few points IE; from 55 to 57.
Most off Idel flat spots are caused by too lean of Idel jets. Adjusting the accel pumps is the next thing to do after getting the Idel jets correct.
PostPosted: Wed Apr 27, 2011 9:48 am
Ody i bumped the idles to 55 before i ever put them on, so they should be plenty big enough. Ima mess with the accelerator pumps today. As for all the other jets, I can remember exactly what I put in it, But went with the recommendations guy at the vw shop said should be right for the 1915 I do remember i went with the 0bypass jets
"IT IS WHAT IT IS"
PostPosted: Wed Apr 27, 2011 12:52 pm
What size venturies are in them?
PostPosted: Wed Apr 27, 2011 2:16 pm
not familiar with the pieces parts and names. But F11, 155 on the bottom 185 on the center jet. 0 bypass jets, 55idle mix and cant remember the other part. But Its running top notch as of now so ill just have to see what it does when we go riding.
"IT IS WHAT IT IS"
PostPosted: Wed Apr 27, 2011 9:26 pm
Venturies are the things the fuel squirts down into. Basicaly the barrels. Sometimes you can see the numbers on them. They go from 28 on up past 40. These can also be the problem.
PostPosted: Wed Apr 27, 2011 9:36 pm
Ic seems to be running pretty good, Might have it a little rich but gonna go with it and see what happens
"IT IS WHAT IT IS"
PostPosted: Wed Apr 27, 2011 10:35 pm
Better rich than lean
PostPosted: Wed Apr 27, 2011 11:32 pm
For sure. :mrgreen: rather replace plugs than pistons! lol
"IT IS WHAT IT IS"
