It is currently Tue May 05, 2026 4:59 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: new 4 seat project
PostPosted: Mon Apr 11, 2011 4:57 pm
Image What do I have going on with the the rear tires? Need help
PostPosted: Mon Apr 11, 2011 5:17 pm
arms on the wrong side :?: just a guess
PostPosted: Mon Apr 11, 2011 5:30 pm
I thought about that, but the arms are stamped left and right, but that doesn't mean they are right.
PostPosted: Mon Apr 11, 2011 6:24 pm
Looks fine to me, wish ours were like that :lol:
PostPosted: Mon Apr 11, 2011 7:18 pm
How loose is your torsion.. You might be able to raise the back.. Mine do the opposite because my torsion was too high..
PostPosted: Mon Apr 11, 2011 7:20 pm
PostPosted: Mon Apr 11, 2011 7:44 pm
Image No torsion bars, coil overs
PostPosted: Mon Apr 11, 2011 8:49 pm
WHERE THE SHOCK BRACKETS ALREADY ON THE ARMS OR DID YOU ADD THEM ? IT LOOKS LIKE THE ARMS POSSIBLY ARE ON THE WRONG SIDE IF YOU ADDED THE BRACKETS .WILL THEY STRAIGHTEN UP IF YOU JACK IT UP OFF THE GROUND ?
PostPosted: Mon Apr 11, 2011 9:19 pm
Added the shock brackets on them. they are marked left and right, but I think i will flip them anyway just to see what happens. Will the placement of the washers on the pivot bolt cause this?
PostPosted: Mon Apr 11, 2011 10:46 pm
is it possible that the pivot mounts are lower than the centerline of the tube? Or if the pivot is not square with the torsion?
PostPosted: Mon Apr 11, 2011 11:40 pm
also looks like the shocks are welded a little far out to me , or you need to repositon the tabs
PostPosted: Tue Apr 12, 2011 10:29 pm
flipped trailing arms & moved shock mounts in. Is this what it should be like?
PostPosted: Tue Apr 12, 2011 10:57 pm
that looks much better to me, at least it will gain ground clearance like that and the tires should also flatten out as the suspension compresses or add weight to the buggy per driver/passenger, etc.
PostPosted: Tue Apr 12, 2011 11:17 pm
much better . Project is looking real good
PostPosted: Thu Apr 14, 2011 12:14 pm
I know if you have those inner pivots off even a hair, it will show big time at the wheel. I've done this before! :roll:
PostPosted: Thu Apr 14, 2011 7:13 pm
PostPosted: Thu Apr 14, 2011 7:23 pm
It is awesome to keep seeing all these kick ass 4 seaters. Looks great..
PostPosted: Thu Apr 14, 2011 8:13 pm
yes they will! I finaly fixed mine over the winter. mine had neg camber and toe in because pivots were mounted wrong :roll: Nice looking buggy. Keep the pics coming. :)
PostPosted: Thu Apr 14, 2011 8:44 pm
Looks good,looks better now that the arms are flipped.did you put the right side on from looking at the back of the buggy or the front of the buggy.I've done the same thing with the torsion bars,sometimes I have brain farts.lol.keep pics coming.Chad :mrgreen:
PostPosted: Thu Apr 14, 2011 11:53 pm
They were stamped left and right, when I put them on the first time. I looked from the back, but who knows what they did when they were made.
PostPosted: Sat Apr 16, 2011 10:40 pm
Getting closer for paint
PostPosted: Sun Apr 17, 2011 6:57 pm
Need to add a diagonal support to those tree bars so they dont bend up. I think :roll:
PostPosted: Tue Apr 19, 2011 11:33 pm
PostPosted: Fri Apr 29, 2011 3:27 pm
ImageImage[img]http://i1211.photobucket.com/albums/cc422/MKJB/011-1.jpg[/IM[IMG]http://i1211.photobucket.com/albums/cc422/MKJB/016.jpg[/img]G]Image
PostPosted: Fri Apr 29, 2011 4:10 pm
