It is currently Mon May 04, 2026 1:55 pm
 Post subject: wtb 3 rib bellhousing
PostPosted: Wed Mar 09, 2011 2:32 am
In need of a 3 rib bell housing, any Ohioans nearby
PostPosted: Fri Mar 18, 2011 2:05 am
anybody???
PostPosted: Fri Mar 18, 2011 5:01 pm
I will have a broken 3 rib at the lansing buggy show. 150.00 for the whole thing. It binds when you put it in gear, never took it apart could be something easy or difficult to fix. Thanks Dave T
PostPosted: Fri Mar 18, 2011 6:36 pm
hows the condition of the bellhousing? Would you be willing to sell just that?
PostPosted: Sun Mar 20, 2011 9:17 am
Bell housing is fine. I will sell just the bell after the Lansing show if the whole trans does not sell. Thanks Dave T
PostPosted: Sun Mar 20, 2011 9:27 am
ok, let me know.
PostPosted: Mon Mar 21, 2011 9:14 pm
I have one without the mounting ears on the top if your interested.Give me a call and we can work out the details.513-594-2879 anytime after 6p.m.
PostPosted: Tue Mar 22, 2011 1:52 pm
i really need one i can bolt on and use..thanks though
PostPosted: Wed Mar 23, 2011 8:19 am
Nick are you using the transmission straps as mounts? If so those top mounting ears won't matter. Most buggys run the straps and do not make use of those mounting ears on the top.
PostPosted: Wed Mar 23, 2011 9:57 am
glad you said something kyle, i was thinking of the motor mount ears. i need to snag this
PostPosted: Wed Mar 23, 2011 5:21 pm
damn 3.5hrs
PostPosted: Thu Mar 24, 2011 11:35 pm
just go up to la products. pats got them for 85 a piece with a core. or just buy a front shift 6 rib housing. shes got them sitting on the shelf and but a 6 rib starter. its alot closer than 3.5 hours away.
PostPosted: Fri Mar 25, 2011 8:42 am
i ve got one without ears im connellsville pa 15425 if this helps let me know
PostPosted: Fri Mar 25, 2011 2:00 pm
Thanks buggie junky but your not much closer. If i dont end up getting the one from aaron, you will hear from me. Wasn't looking to spend that much but worst case ill hit up LA.
PostPosted: Sat Mar 26, 2011 8:41 pm
if you want a 6 rib one i have one i think. i forget what you have to do to make a normal starter work, i think you just mill off the mounting plate surface of the bellhousing.
PostPosted: Sun Mar 27, 2011 5:07 pm
Jeff, do you know anybody that can do that?
PostPosted: Sun Mar 27, 2011 5:49 pm
Eric DeBord,,,MadMike
PostPosted: Sun Mar 27, 2011 9:46 pm
or any local machine shop :wink:
lets just ride
PostPosted: Sun Mar 27, 2011 10:24 pm
I really just want to get a 3rib one, but if i go with the 6rib housing do you know the specs on how much i need to shave off of it? Would it be easier and/or possible to mill the plate on the starter instead?
PostPosted: Mon Mar 28, 2011 9:23 am
I dont remember exact but its not much.. Measure form the mounting base of starter to end of bellhousing and that will tell you.
PostPosted: Mon Mar 28, 2011 9:35 pm
I think it is about 1/4 inch , , the 6 rib bell has a beefier thro out bearing arm. If you are set on a 3 rib bell, and can't find one cheaper,,, I have one I will sell for $45 shipped.
PostPosted: Tue Mar 29, 2011 12:49 am
I think a 3 rib bell is my best bet, I just considered the 6 because jeff is so close to me and im anxious to get one soon. Firebug think you can get some close up pics to me sometime tomorrow? is it ready for me to pop on and use? thanks for the help!
PostPosted: Tue Mar 29, 2011 6:37 am
sure,,I was saving it for a spare build but I don't seem to be getting it done
