It is currently Mon May 04, 2026 10:55 pm
 Post subject: 930 cv joints
PostPosted: Tue Mar 15, 2011 8:05 pm
just put 3x3 trailing arms and 930 cvs on buggy....cvs feel loose and jerky(all bolts are tight) is this typical of 930 joint ? jerky meaning if i accelerate,let off and hit gas again,it feels like trans mount loose but its the cvs
 Post subject: Re: 930 cv joints
PostPosted: Tue Mar 15, 2011 9:11 pm
no nothing should feel loose I have 3x3 and 930s on both my cars and there are tight.what angle are your axls at :?: did you put the snap ring on the end of your axles :?: can you move your axles in and out :?: what length axles did you get :?: should be 19 1/4
PostPosted: Wed Mar 16, 2011 8:25 am
check your angle. ideally you want to shoot for 20-22* sitting and max out no more than 23* till everthing gets broken in or worn in. A new set on lobros that arnt preped can break pretty easily till worn in a little.
PostPosted: Wed Mar 16, 2011 8:05 pm
put rings on,barely any angle on them....axles do move in and out,and not 100% sure on length,they came as a kit from appletree
PostPosted: Thu Mar 17, 2011 8:28 am
also the cv has a groove machined on the outside,i have the groove closer to the flanges,and stub axles
PostPosted: Thu Mar 17, 2011 9:31 am
Read this it tells you how to assemble them and clock them.
http://www.outfrontmotorsports.com/cv_assembly.htm
PostPosted: Thu Mar 17, 2011 2:16 pm
called appletree this morning...theyre going to send me 4 new cvs and a ups shipper to send old ones back...no charge,now thats customer service! he said they might be polished balls that dont match cages...?
PostPosted: Tue Mar 22, 2011 4:03 pm
got the 4 new cvs from appletree...put them on today...still loose and jerky...wtf?
PostPosted: Tue Mar 22, 2011 6:01 pm
how easy did the cups go up on the tranny your output shafts could be wore
PostPosted: Tue Mar 22, 2011 6:23 pm
Use channellocks to hold outside of each cv, then twist to see if slack is actually in cv.
PostPosted: Tue Mar 22, 2011 6:38 pm
output flanges are correct and new...i can hold tranny flange with one hand,turn rotor back and forth with other hand and feel and see the play in cvs...
PostPosted: Tue Mar 22, 2011 9:17 pm
id check rotor and stub axles, for play next! never heard of a set of 930s with slack and id say its next to impossible to get a second set with play :wink: it has to be in your original parts somewhere
lets just ride
PostPosted: Tue Mar 22, 2011 10:59 pm
Alot of 930 cvs that are sold as race prepped [empi], are just a chromoly 930 with smaller balls added to enable them to be set at a steeper angle.
That might be the slack your experiencing.
They tend to pop more, but I wouldn't worry too much about them.
PostPosted: Wed Mar 23, 2011 3:34 am
new everything...trailing arms ,bearings,stubs,rotors,cvs,axles,etc
PostPosted: Wed Mar 23, 2011 3:37 am
the guy at apple tree said they might have been race prepped...supposedly the second set was standard 930 cv...he said if i had problems with any of the new ones send them back too...im gonna call today and see if i can send cvs and axles back assembled and he can deal with it....already tired of changing cvs...
PostPosted: Wed Mar 23, 2011 8:58 am
new everything...trailing arms ,bearings,stubs,rotors,cvs,axles,etc[/quote]
well if all that's new is your tow way out causing the cv's to run crooked from the trans i have never heard of or seen 930s doing this especially 2 sets of them
PostPosted: Wed Mar 23, 2011 12:10 pm
without being there, or hearing it i could be wrong, but its not abnormal for them to click. Mine always have, new or old, race preped or stock.
