It is currently Tue May 05, 2026 2:01 am
Post new topic Reply to topic  [ 78 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Mar 14, 2011 12:36 pm
I got my starter on ebay new for 55
Also the rad hoses are 1 3/8 right or did I miss something
The 2 plugs I think one is air temp. The other crank sensor but where is it at on the motor bc I did not see it
PostPosted: Mon Mar 14, 2011 5:30 pm
The crank sensor is on the block behind the orig. starter location. On mine it had a 6" pig tail that plug into the sensor and the other end in to the harness.
The air temp sensor is in the factor air box assembly. It in the tube that attaches to the throttle body.
PostPosted: Mon Mar 14, 2011 7:50 pm
i think it is the crank one im missing the plug looks just like the air temp one just shorter pig tail. I have one round plug that when beside where the Knock Sensor is bolted to the block but im not seeing the one for the crank anyone have a pic mine is a 45 min ride away
thanks guys
PostPosted: Mon Mar 14, 2011 9:25 pm
from left to right. knock sensor,oil presure sender,and crank sensor. crank sensor is small and hard to see in this pic. its to imediate right of oil sender.
PostPosted: Mon Mar 14, 2011 9:36 pm
thanks mine must be missing I didnt see it
also do you have a part # for a belt i tried to get one but they said they didnt have one for just a the crank and alt.
And one more on your grounds in the harnesse, did you guys run them all back to the frame
PostPosted: Mon Mar 14, 2011 11:03 pm
from the factory my harness was grounded on the back of the block, my adapter plate has a threaded hole in it for the ground but my engine and adapter plate are a little different from yours
PostPosted: Tue Mar 15, 2011 6:13 am
Just tell them you have a 2003 sunbird without AC.
Dayco #5050345 at Advance Auto Parts.
http://shop.advanceautoparts.com/webapp ... ELTAMS____
PostPosted: Sat Mar 19, 2011 5:53 pm
thanks for the Part # on the belt and also I had the crank plug I was miss the oil one THANKS EVERYONE 8) :D
Well had a short day today but did get the Rad. on and the Exhast if i can get the hoses for the rad and get my box made for the ECU im going to see if it will do some talking tomorrow :lol:
PostPosted: Sun Mar 20, 2011 7:55 pm
Well got the fuel lines in today and got it to fire up and it sounds sweet!!
I will have to post a video next weekend when I go work on it.
Also anyone thinking about the starter it works great turns It right over. 8)
PostPosted: Mon Mar 21, 2011 1:57 am
Cant wait to hear it that exhaust looks sweet.
"IT IS WHAT IT IS"
PostPosted: Mon Mar 21, 2011 8:54 pm
Looks good ! I know this has been asked before some where but how much weight does a ecotec add over a vw?
PostPosted: Mon Mar 21, 2011 10:01 pm
NOWHERE near enough to outweigh (ha ha) the benefits of having one. :mrgreen: Seriously the difference with radiator was around 100 lbs.
PostPosted: Tue Mar 22, 2011 9:33 pm
yep I say about a 100 or less my buggy only sets 1/2" lower then with my old vw :lol:
I have not felt the benefit of the power yet but hearing it I feel like its the best thing I have done to my buggy yet :mrgreen: :mrgreen:
PostPosted: Sat Apr 02, 2011 9:12 pm
got some more stuff done :lol:
PostPosted: Sun Apr 03, 2011 6:58 am
is that a surge tank fuel setup you built there?
PostPosted: Sun Apr 03, 2011 7:54 pm
yes in the first pic its the box without paint and in the 3rd pic you can see the 2 pumps.
PostPosted: Sun Apr 03, 2011 8:08 pm
Looking good
PostPosted: Sun Apr 03, 2011 9:41 pm
hyde wrote:
Looking good
Thanks Hyde
PostPosted: Mon Apr 04, 2011 9:02 pm
PostPosted: Tue Apr 05, 2011 4:29 pm
here is a bad cell video but here it is running and one day it will be running again :(
PostPosted: Tue Apr 05, 2011 5:17 pm
what type of fuel pump you runnin?
PostPosted: Tue Apr 05, 2011 7:25 pm
This is the pump im running, should work right.
http://www.summitracing.com/parts/SUM-G3138/
PostPosted: Tue Apr 05, 2011 10:23 pm
Thats the pump i'm using.
PostPosted: Wed Apr 06, 2011 7:40 am
Same pump here. Noise
PostPosted: Wed Apr 06, 2011 8:06 pm
Thats exactly what I was thinking from the vid. Would drive me crazy
cron
