It is currently Mon May 04, 2026 10:02 pm
PostPosted: Mon Mar 07, 2011 8:40 pm
I am looking for a reasonable 2 barrel weber carb if anyone has one they want to sell pm me please thanks
PostPosted: Mon Mar 07, 2011 11:30 pm
are u looking for a idf or progressive carb.
PostPosted: Tue Mar 08, 2011 6:31 am
I have a single Dellorto DLRA 40 setup for sale. This was on my wife's 1915 before she went to dual 44's. It is a complete setup and includes 2-stage filter with cast aluminum adapter, aluminum manifold, two end castings with seals, and center-pull linkage. This carb has been fitted with CB performance's update kit that includes larger vents, horizontal discharge tubes, and extended idle jet intakes (see kit at this link):
http://www.cbperformance.com/catalog.asp?ProductID=522
The price is $300 complete or $250 for carb and manifold only. This is a firm price and does not include shipping. If you would like for me to email some photos of the setup please email me at:
dhall132@carolina.rr.com
Thanks,
Dale
Lets RIDE!
PostPosted: Tue Mar 08, 2011 11:37 am
Don't really now all I now it goes on a stock 1600 and the one on there is done for and that it is a weber
PostPosted: Wed Mar 09, 2011 6:04 pm
Would like like to have idf now that I now the diffrence
PostPosted: Sun Mar 13, 2011 10:58 am
It's pretty important to know which carb you currently have. An IDF will not bolt on to a progressive manifold and vice versa. Easy way to tell, are the two barrels aligned side by side, or front to back? Or, remove the air cleaner and look at the throttle plates as you work the linkage, does one plate open before the other? If so, it's a progressive, if they open simulatneously, it's an IDF. Or, search the web for pictures, and identify it that way. I have a few progressives around, if that is what you need.
Check out www.Thegoodvolks.com!
PostPosted: Sun Mar 13, 2011 7:13 pm
look at the sponsor page, and call gary davis or tim at southern buggys :wink: they can tel you what u have and also tel you what you need!!! and then ship it to ya! its worth the call and you wont be steered wrong :wink:
lets just ride
PostPosted: Mon Mar 14, 2011 5:47 pm
We called southern buggies that is how we figured out what type we have it is a progressive thanks for all help
