It is currently Mon May 04, 2026 8:10 am
 Post subject: bearings for a bj beam
PostPosted: Wed Mar 02, 2011 7:42 pm
does anyone happen to have a part number for the bearing inside a ball joint front end?
or know where to get them?
thanks
PostPosted: Wed Mar 02, 2011 8:21 pm
Most drive the bearings out and replace them with some sort of plastic, polyurethane or delrin. Any of our parts sponsors can help with that.
PostPosted: Wed Mar 02, 2011 9:26 pm
where u at in ohio? you could get them from drews off road in hamilton, i used the red polyurethane ones on mine they work ok but ive read other people talk about a different brand that were a different color that were better a better fit cause its pretty hard to get the arms back into the red ones, some say you can grind out the inside of the red ones a bit to fit easier but i just used grease and a big ass hammer!! and if you dont have the zirk grease fittings on your beam , while you have the arms out replacing the "bearings" pack the beam full of grease with a grease gun! hope this helps
PostPosted: Thu Mar 03, 2011 8:55 am
try the ones from bug pack. I have had better luck with them, they are harder than other brands i have tried .
PostPosted: Fri Mar 04, 2011 7:15 pm
thanks for the replies, but im trying to stay with the roller bearings instead of plastic bushings. i think i have it taken care of
thanks
