It is currently Mon May 04, 2026 4:33 am
 Post subject: fuel surge tank
PostPosted: Thu Jan 13, 2011 10:32 pm
Has anyone running a WC made and running fuel surge tank? Is it even needed?
Thanks
 Post subject: Re: fuel surge tank
PostPosted: Fri Jan 14, 2011 9:14 am
Yes, I made one this year for my race buggy. Worked out real nice.
PostPosted: Fri Jan 14, 2011 8:39 pm
what is a fuel surge tank?
PostPosted: Sat Jan 15, 2011 12:14 pm
thanks im going to make one when i put mine motor in 8)
What pump did you use as the low pump, on the main one a was going to use a E2000.
this will help you know what a surge tank is
http://www.ratdat.com/?p=168
PostPosted: Sat Jan 15, 2011 5:18 pm
Even more puzzling, what's the need? Plumb your fuel system correctly there is no need for any surge tank.
PostPosted: Mon Jan 17, 2011 9:13 am
There is a need for a surge tank in my race buggy. Hard cornering would leave me spitting and sputtering and even stalling. I have also heard it is common in rally cars and road racing cars. I am just using a low pressure electric fuel pump for my supply to the tank.
PostPosted: Mon Jan 17, 2011 5:09 pm
I dont really have a need for it but it sounds like a good idea to me. If im going up a hill I dont want to lose my pickup.
PostPosted: Mon Feb 14, 2011 7:55 pm
Just put a sump and baffles in your aluminum tank and you shouldnt have any problems.
PostPosted: Mon Feb 14, 2011 8:51 pm
We always just used to run a sump and a set of baffle plates with the tank in the rear.
Now we're running a plastic tank that's quite tall and narrow up front, plus foam, seems to be fine.
