It is currently Mon May 04, 2026 7:27 am
 Post subject: CLUTCH FOR THE STREET
PostPosted: Thu Feb 10, 2011 10:15 pm
My buggy will be on the street 80% of the time im going to run a ecotec. I was going to order a Kep. stage 2 with a 6 puck but Kennedy told me they would not run that on the street at all (acted like it would rip my head) they said i should run some HD stock type. what are some of you guys running on the street.
thanks
PostPosted: Thu Feb 10, 2011 10:25 pm
A stage 2 and a cush lock disc shouldnt be to bad.
PostPosted: Thu Feb 10, 2011 10:50 pm
stage 2 with a 6 puck is what i would run,i think a stage 2 with a stock clutch or cushlock would slip,ive ran both with a vw motor and cushlock would slip in higher gears,with that ecotech u gonna need some good stuff,i run a 6 puck brass clutch and they are perfect,,nothing like a 4 puck
PostPosted: Thu Feb 10, 2011 10:54 pm
I have had my best luck with 6 pucks. but that is all woods. I liked my stage 2 when I ran it too.
PostPosted: Thu Feb 10, 2011 11:22 pm
buddy has ecotec in light buggy he runs in woods 99%. he has stage 2 pressure plate and a cushlock. for the most part it works great. would think is fine on street unless your trying to set new wheelie record
PostPosted: Thu Feb 10, 2011 11:23 pm
what does it feel like on some blacktop or have you had it on some.
I had a stage 1 with a cushlock with a 1915 on the street it was ok but did lockup fast and hard would it be about the same or harder??
PostPosted: Thu Feb 10, 2011 11:27 pm
I would like it to stand up nice but not from every LIGHT :shock: at the same time I would like my neck to not hurt after every ride also 8)
PostPosted: Fri Feb 11, 2011 10:26 am
it feels jus like a stock clutch,it dont shake like a 4 puck,i think u will like it,u wont have to buy another clutch for a long time
PostPosted: Fri Feb 11, 2011 10:48 am
Outfront Motorsports told me it was pretty much a toss up. 6 puck will never slip but is like a light switch on pavement. You have to get used to EXACTLY where your clutch engages or you'll stall on street a lot. They told me stock style would work great (for a while) but hard starts and hill climbs would kill it eventually with that much power. Damned if you do... Damned if you don't... :roll: I bought both. I am gonna try the 6 puck. If I can't get use to street driving it, then I will switch down to stock and see how long they really do last.
PostPosted: Fri Feb 11, 2011 12:35 pm
I think you will like the 6 p,,,do you have cable pedal or hydraulic? mine is cable
PostPosted: Fri Feb 11, 2011 1:26 pm
I ran a 6 puck for a while with a stage 4. It seemed to grab great. Just a little chattery on an easy launch, nowhere near as bad as a 4 puck, but dont think I'da liked it on the street. Worst thing about it to me was in a tight spot had to slip clutch repeatedly and it smoked it a little and was never the same. Once a stock disc cools (as long as you dont flat out roast it) it will grab again like normal. I liked kushlok better, switched it back. A sprung center stock or kushlok disc shouldnt give u any chatter at all and will be very smooth, and with a stout pressure plate it should hold the 170(??) or so hp of the ecotec. If you run hydropedals, use the smallest m/c you can find (prolly 5/8) and the stage 4 is not hard to push. Bad thing about a stage 4 on a vw is its hard on your thrust, but dont think you have to worry about that with a w/c engine. JMO
PostPosted: Fri Feb 11, 2011 5:10 pm
:mrgreen: :mrgreen: i agree street is alot different than the woods you need a little slip. and i run a 2276 with a stage 2 cush lock and i like it and it dont slip. not saying they wont cause i smoked a cush lock before :shock:
PostPosted: Fri Feb 11, 2011 6:09 pm
get a sprung hub 6 puck with the stage 2 and youll be fine
PostPosted: Fri Feb 11, 2011 7:08 pm
I ran a stage 2 & 6puck for about 100 mile on back road 1 day & was fine . But you my like a stage 3 & cush lock .
PostPosted: Fri Feb 11, 2011 7:44 pm
I have a hydraulic pedal and im really thinking about the 6 puck but will the will it be harder on my trans and cv's then the cush lock would.
PostPosted: Fri Feb 11, 2011 8:31 pm
thanks
Thats what kennedy recomended for me also so i went with it. Its been fine for me so far. 3 trips to wellsville,1 trip to wheelers some play time at a friends,drunken flat tracking at a holloween party and a thousand or so street miles last summer. I'm happy with it so far.
PostPosted: Sat Feb 12, 2011 3:45 am
id recommend a stage 2 kennedy pressure plate and a kush loc clutch disk but thats jmo
