It is currently Mon May 04, 2026 7:44 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
PostPosted: Mon Dec 27, 2010 2:58 pm
looking for a vw, either stock or built.( nothing that a 3 rib cant handle). thanks
PostPosted: Mon Dec 27, 2010 3:18 pm
Friend of mine has a complete 1915 that needs freshened up. Ran all season, never had to change a spark plug.
You want I'll check on it.
PostPosted: Mon Dec 27, 2010 4:30 pm
You didnt buy the one off packrat2056?
PostPosted: Mon Dec 27, 2010 5:19 pm
I bought everything off of him but the motor. Mike by freshened up you mean?
PostPosted: Mon Dec 27, 2010 5:54 pm
i have a great running 1600 that smokes a little and has only 3/4 inch end play thats off the buggy now :twisted: :lol:
PostPosted: Mon Dec 27, 2010 6:38 pm
Just wondering why not the motor?
PostPosted: Mon Dec 27, 2010 6:39 pm
I think you better put her down!!!!!Image! :shock: :mrgreen:
PostPosted: Mon Dec 27, 2010 7:46 pm
yeah I pulled a valve cover and saw that the heads were Mofoco 042s so the price went up a little
PostPosted: Mon Dec 27, 2010 8:23 pm
should have went down, MOFOCO=MOF*CKINJUNK
:twisted:
PostPosted: Mon Dec 27, 2010 8:27 pm
:twisted:
:twisted: :mrgreen: :twisted:
PostPosted: Mon Dec 27, 2010 9:45 pm
The crank has a little more end lash than it should, freshened up bottom end at least.
PostPosted: Tue Dec 28, 2010 10:11 am
buddy has a couple of them on shelf. anything from stock 1600 to a really nice 2180 thats all new. he is in the warren ohio area. i will pm you his number
PostPosted: Thu Dec 30, 2010 12:07 am
Pak Rat 2056,
I hope you were joking about Mofoco, If you have Mofoco heads then the spark plugs need indexed because they are not drilled and tapped to the same depth because the quality is that poor. I saw a "freshly rebuilt 6 rib" from Mofoco in November, it was PURE TRASH. It is sad to see people selling this crap. In my area, Mofoco parts are worth about half what scrap is selling for. Seriously Mofoco parts are that bad.
Good Luck
Kenric
PostPosted: Thu Dec 30, 2010 7:25 pm
my two other motors are fitted with CB 044s the engine I would like to sell has mofocos yes I heard they are not great quality but they were on the car when I got it, it does run very good for a small cc motor and mofocin junk heads are better then no mofocin heads at all!
PostPosted: Thu Dec 30, 2010 9:01 pm
i agree with donnie , this is all mofocun crazyness !! thats so fun to say mofucas :twisted:
PostPosted: Thu Dec 30, 2010 9:42 pm
i was just voicing my opinion on the heads, I had a set destroy a brand new motor.
PostPosted: Thu Dec 30, 2010 11:29 pm
I'm in Zeeland MI 49464 and have a 1776 that will need to be assemblied. Thanks Dave T Image , Image , Image , Image .
PostPosted: Sat Jan 01, 2011 5:45 pm
dave, dont think im experienced or familiar enough with vw engines yet to build one from scratch. Id like to get one thats running or atleast fully assembled. I would be overwhelmed with just a box of parts :shock:.
thanks, nick
PostPosted: Sat Jan 01, 2011 5:55 pm
3/4 end play?? fill me in on this please. little bit of smoke never hurt nobody
PostPosted: Sat Jan 01, 2011 6:01 pm
Does that mean I would need to get a new crank? or what causes that?
PostPosted: Sat Jan 01, 2011 6:20 pm
Needs new main bearings. I know almost nothing about VW motors, nor do I want to. This motor has about .035 end lash, that means the thrust bearing is wiped out, again I'm guessing. On a VW that still might be fine IDK.
Motor is complete with Mesa oil cooler, single Webber, 090 dizy, remote filter, Kennedy stage 2 PP, fuel pump and if you want it can have a power steering pump and stuff with it.
PostPosted: Sat Jan 01, 2011 7:09 pm
so .o35 is too much endlash? i did some investigating and if that is so, then the main bearing dowpin can oval out the dowpin hole and then the case is trashed. someone correct me if I'm wrong.
PostPosted: Sat Jan 01, 2011 9:16 pm
Yes good endplay is like .003 to .006 the case will probably need to be machined. read this.
http://www.aircooledtech.com/end_play/
PostPosted: Sat Jan 01, 2011 9:23 pm
i was just playin around my motor was pushin oil out of every hole and smokin real bad the last ride it would need split and case done and bearings and rings to be correct ! i would ck into mikes freind jimmys 1915 and see what he wants it was a good runnin engine ! his screen name is jrk and he is a pa boy ( raadeator) :twisted:
PostPosted: Sat Jan 01, 2011 11:34 pm
[/quote]Yes good endplay is like .003 to .006 the case will probably need to be machined. read this.
http://www.aircooledtech.com/end_play/[/quote]
good reference, sounds like a hassle to check it, is this something that happens often?
