It is currently Mon May 04, 2026 2:14 pm
 Post subject: Heim Joint Help needed.
PostPosted: Wed Jun 15, 2011 2:32 pm
I have 3/4" heim joints to redo my front end, and get rid of bump steer, I hope. :roll: The problem is, well, I forgot to get misalignment spacers. What do I need and where do I get them?
PostPosted: Wed Jun 15, 2011 3:56 pm
Found these, what do you guys think.
http://www.polyperformance.com/shop/Syn ... -p-19.html
PostPosted: Wed Jun 15, 2011 8:09 pm
where did you get the hiems from they should have the misalignment bushings also. you could try the chassis shop in Michigan by david allen racing. those would work that polyperformance has also. Do you have a fastenall or any other nut and bolt store by you if they don't have it they could probably order them for you.
PostPosted: Wed Jun 15, 2011 8:14 pm
Here is where I got some...
http://cgi.ebay.com/ebaymotors/3-4-5-8- ... arQ5fParts
PostPosted: Wed Jun 15, 2011 10:19 pm
Just ordered them. Thanks guys.
PostPosted: Thu Jun 16, 2011 7:53 am
Those you posted are the high style spacers, you will need the regular ones, try Poske's racing....you can get them fast and cheaper than most stores according to my experience....here is the site....http://www.poske.com
PostPosted: Thu Jun 16, 2011 9:07 pm
????? The high misalignment spacer allows your heim to fully travel without any binding. If your looking to just use a smaller bolt with a big heim thats a different story.
PostPosted: Fri Jun 17, 2011 12:17 pm
I see what you mean.....my bad on that part....I did not know how the ones pictured was made 100%, I thought it was the high-style ones, I do not have them.....I just have the standard ones :oops: :oops:
