It is currently Mon May 04, 2026 8:52 am
 Post subject: air filter options
PostPosted: Mon Oct 14, 2013 10:51 pm
im having serious problems keeping dirt out of my cabs they are 40 webbers im currently running just the filter with the bag over it and cant keep dirt out of the damn idle jets what better ways is their to keep them clean
 Post subject: Re: air filter options
PostPosted: Mon Oct 14, 2013 11:09 pm
Jet doctors are a must. Unless you run elaborate air filter system. If you dont have jet doctors,get them,they work.ill get the info for you if you need it
PostPosted: Mon Oct 14, 2013 11:11 pm
WB Competitor
get jet doctors...i have dual 44 webers and i never have a idle jet clog up.
PostPosted: Mon Oct 14, 2013 11:15 pm
I do not have them where can I buy them
PostPosted: Mon Oct 14, 2013 11:54 pm
You shouldn't need them if your air filter is working. All they do is raise the air intake higher so the dirt goes in the cylinders instead of the jets. If you have proper air filter that's working how it should you don't need them.
http://www.cbperformance.com/ProductDet ... tCode=7557
PostPosted: Mon Oct 14, 2013 11:56 pm
here you go...http://www.cbperformance.com/ProductDet ... tCode=7557
PostPosted: Mon Oct 14, 2013 11:58 pm
Thanks will give this a try
PostPosted: Tue Oct 15, 2013 1:11 am
jesse, I was at joes tonight and heard it run... I believe your fuel line is breaking down on the inside :idea: old lines with no filter..
LEGALIZE BLUEGRASS!!!
Save a tree... eat a Beaver
PostPosted: Wed Oct 16, 2013 7:37 pm
Same problem I'm having!!
PostPosted: Wed Oct 16, 2013 8:40 pm
im not gonna jump to conclusions cause there is a third party here, but, i run a fuel filter out of my tank before the pump and one after the pump before my carb :idea: and fuel line is not that expensive, replace all that shit if you think its old.but either way you need the jet doctors regardless ! oh and velocity stacks also help out as well to keep all the air sucking at a higher spot other than rite at the top of the carb to keep shit out... been down this road and believe me it helps ALOT
PostPosted: Thu Oct 17, 2013 12:06 pm
run a foam outter filter!!! Trust me on that, racing for hours in heavy dust taught me a few tricks. if you can increase your idle jet size, that helps ALOT too!
PostPosted: Thu Oct 17, 2013 2:19 pm
PostPosted: Thu Oct 17, 2013 2:21 pm
PostPosted: Thu Oct 17, 2013 2:22 pm
PostPosted: Thu Oct 17, 2013 2:23 pm
PostPosted: Thu Oct 17, 2013 2:27 pm
This system here works great it is sealed at the carburetors and as always drawing fresh cool air from the center of the buggy . And stead of hot air above the head and the mud and dirt from the tires don't affect the filters it is a little costly but personally I say it's the best system out there
PostPosted: Thu Oct 17, 2013 4:57 pm
PostPosted: Thu Oct 17, 2013 10:34 pm
i ordered me some 55 idle jets the jet doctors and the foam to go around the breather i like yalls sealed systems if this dont work i may try one where do you buy the part on the carb aso gonna change all fuel line with that blue stuff for boats and add 2 more fuel filters
PostPosted: Fri Oct 18, 2013 7:49 am
dont forget you (should) already have strainer/filters at the fuel line port on your carbs
