It is currently Mon May 04, 2026 6:17 am
 Post subject: Good rear arms
PostPosted: Sat Sep 22, 2012 7:47 pm
Looking for some good rear arms. Does anyone still have madmikes phone number? I heard his are bulletproof.
WTFO
Loud pipes save lives.
 Post subject: Re: Good rear arms
PostPosted: Wed Sep 26, 2012 6:53 am
I have a set. They look like they are indestructible. I haven't put them on yet but I heard good things about them. The bearing carrier that Mike uses holds a double row outer bearing and 2 stock inner roller bearings. That's like 4 sets of bearings on each side.
Norm
Here's his number,
724-650-0816
e-mail, madmike15001@yahoo.com
PostPosted: Wed Sep 26, 2012 7:51 pm
I have a question though, what exactly is the difference between 2x3,3x3 and up???
WTFO
PostPosted: Wed Sep 26, 2012 8:08 pm
the first number is how wide they are and the second is how far back they go from stock
PostPosted: Wed Sep 26, 2012 8:18 pm
If I remember correctly you have a bus torsion. That will make a difference in the arms. Also a bus is already 2x3 when compared to a car torsion.
PostPosted: Thu Sep 27, 2012 8:02 pm
I don't think Mike is making parts anymore. Last time we spoke he was calling it quits. He may want you to take down his phone number in the previous post. Maybe not......
PostPosted: Fri Sep 28, 2012 7:43 pm
Alright, i need to get my head out of my @ss and figure out if i want to rip my bus torsion out and run stock class with a car torsion. I will have the tooling, but i need to read over the rules to make sure i don't violate any because i will be pissed if i do all that work and i get thrown into modified anyway.
WTFO
PostPosted: Fri Sep 28, 2012 7:46 pm
I have a car torsion if you want it.....
PostPosted: Fri Sep 28, 2012 9:17 pm
I am interested to find out what class you are wanting to run Class I 1600cc. If you are thinking class I I think you are limited to stock width X 1" over stock. I really need to get a rule book for the off road sanctioning group in the norther states any one know were to find?
PostPosted: Fri Sep 28, 2012 9:30 pm
I have not spoke to mike in a while but if he isn't making arms you could try Sawyer ....
But I don't know if he is making arms anymore either :?
PostPosted: Fri Sep 28, 2012 10:14 pm
I can get you a set of three x three from my fabricator in California. I can call for current price if you let me know what you want, 2x3, 3x3, 3x5 mild steel or Chromoly. I can get them with new CNC hub VW type 1 or micro- stub. I will also need to verify this is for a type 1 torsion.
This fabricator builds arms for Mckensie and Kar tech all Made in the USA.
PostPosted: Sat Sep 29, 2012 5:58 am
Last time I spoke to Mike he said same thing about being done making parts.
PostPosted: Sat Sep 29, 2012 6:47 am
Appletree makes a nice arm.
PostPosted: Sat Sep 29, 2012 11:34 am
Here a copy of a e-mail that mike sent me yesterday.
"Hi Norm all is well here, thanks for asking. Roy is correct, I am sorta done making parts for now. I am getting my car finished before I resume building for anyone else. I took at the woodsbuggy topic and no you don't have to remove anything. I will tell anyone who makes contact me whats going on. No problem here. "
So it sounds like Mike is not making any parts now.
PostPosted: Sat Sep 29, 2012 2:07 pm
http://www.lm4w.org/assets/download-information/LineMountainRules.pdf
Here is the copy of the rules, you are correct. For stock class i must have a car torsion, with arms + or - 1 inch.
With a bus torsion you are automatically put into modified class because it is +2 inches. I'm pretty sure regarding rear arms then it would not matter.
So if i decided to go with the stock torsion i WOULD need to go with stock arms then because everything else would be larger than +1 inch??? Correct?
If i decided to run modified class i could run my bus torsion and run ANY ARMS?
WTFO
PostPosted: Sat Sep 29, 2012 3:27 pm
I copied this information from Kartek.com my fabricator builds these for KARTEK, I can get pricing on Monday with cost to your door. 25% less than Kartek or Mickense
Rear trailing arms are available as either mild or chromoly steel and are available for a variety of different bearing housings. Some feature shock mounts and caliper brackets depending on the type of hub used or intended application.
Please specify what type of bearing or wheel hub you are using when ordering.
1600 Series Chromoly Trailing Arms
1600 Rear Trailing Arms
These boxed plated arms are designed for the 1600 classes and can be ordered for either hubs that use VW or micro-stub bearing housings.
Part Number
Description
SUS-05136
1/2-1600 VW Bearing Trailing Arms
SUS-05138
1/2-1600 Micro Stub Trailing Arm
SUS-05137
5-1600 Micro Stub Trailing Arms
PostPosted: Sat Sep 29, 2012 8:29 pm
Hey i was checking out their site before, looking at pumps. Okay, i will be running a sedan tranny, with type 1 cv on the inside and a type 2 cv on the outside. Otherwise i have no idea.
WTFO
PostPosted: Sat Sep 29, 2012 9:30 pm
Ok I will call the fabricator Monday for pricing. You will want the bearing housing for stock VW IRS. Are you wanting mild steel or Chromoly? So Class 1 arms for VW IRS, I will get you a price for mild steel and Chromoly. I imagine you will want them with out shock mounts so you can locate your once you get them bolted on. PM me a telephone and I will call or text the Prices.
PostPosted: Sat Sep 29, 2012 9:32 pm
Alright sounds great man, thanks!
WTFO
PostPosted: Sun Sep 30, 2012 11:07 am
If you want to be competative in the stock class, you need to use a type 1 torsion. The bus torsion is way heavier than the type 1. If the rules let you use +1 arms, you need to take advantage and use +1 arms. It doesn't sound like much but it makes a huge difference. There is a set of +1 arms for sale on thesamba. You might want to look at those if you are on a budget.
PostPosted: Sun Sep 30, 2012 1:44 pm
Alright i will check them out and also thanks for the advice. I will check them out. I know im going to do very badly in modified and at least in stock i may be able to do some work.
WTFO
PostPosted: Sun Sep 30, 2012 11:13 pm
If you can use a set of +1 longer I have a set of Chromoly arms I took off my old s/s race car,I had them shot penned and magnaflux'd to check for cracks(none) type 1 bearing carriers I will let you have them for 275+shipping if your interested pm your phone number or email I'll send pics,,they are very high quality expensive arms that I dont have a use for any longer
PostPosted: Thu Oct 04, 2012 5:58 pm
Any luck, i want to look at the entire picture before i make a decision.
WTFO
PostPosted: Sun Oct 07, 2012 5:34 pm
Did you talk to him?
WTFO
PostPosted: Tue Oct 16, 2012 8:53 pm
Hunter I finally got with my fabricator and I am the weak link here got busy with things. The Chromolly Class 1 arms will run $550 plus shipping but these are built for desert racing and meet all class 1 specs stock width by one inch longer.
