| Eco tec throttle cable &fuel delivery http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=17071 |
| Author: | frankenbuggy06 [ Thu Jun 12, 2014 12:19 pm ] |
| Post subject: | Eco tec throttle cable &fuel delivery |
What are you guys doing to run your throttle cable to the throttle body on the ecotec. And does anyone have a part number for a comparable pump that will run that motor from autozone? So that I can get a warranty with what I buy Sent from my DROID3 using Tapatalk 2 |
| Author: | tw9294 [ Thu Jun 12, 2014 2:53 pm ] |
| Post subject: | Re: Eco tec throttle cable &fuel delivery |
i made my own cable and my fuel pump came from summit. Summit brand i think i paid about 85.00 and its still going 4 years later. |
| Author: | frankenbuggy06 [ Thu Jun 12, 2014 3:11 pm ] |
tw9294 wrote: i made my own cable and my fuel pump came from summit. Summit brand i think i paid about 85.00 and its still going 4 years later. Can I get a picture of how you have it hooked to your throttle body Sent from my DROID3 using Tapatalk 2 |
| Author: | helmetguy [ Thu Jun 12, 2014 7:24 pm ] |
The tb is operated electricly by a motor on the side of it,which is controlled by the ecm. I used a stock cobalt pedal which was controlled through a cable to accelerator pedal that we normaly use on a buggy. I wanted to keep the cobalt pedal dry. Sent from my SCH-I545L using Tapatalk |
| Author: | newbie26 [ Thu Jun 12, 2014 11:43 pm ] |
If he has a 2.2 ecotech he probably has a cable operated version Sent from my DROID RAZR using Tapatalk |
| Author: | frankenbuggy06 [ Thu Jun 12, 2014 11:52 pm ] |
I do have cable. Figured out that one. Used the dogleg off stock vw cable imto where the ball on stock ecotec goes. Now just need fuel delivery. Sent from my DROID3 using Tapatalk 2 |
| Author: | frankenbuggy06 [ Fri Jun 13, 2014 12:09 pm ] |
What do you guys think about using the E2000 pump? Heard it doesnt pull real good but pushes real good Sent from my DROID3 using Tapatalk 2 |
| Author: | Huey [ Fri Jun 13, 2014 12:23 pm ] |
I've had a E2000 pump on my buggy for at least 4 years trouble free so far. Sent from my SM-N900P using Tapatalk |
| Author: | purplerail [ Fri Jun 13, 2014 12:41 pm ] |
E2000 eBay around 35 bucks |
| Author: | frankenbuggy06 [ Fri Jun 13, 2014 12:52 pm ] |
What motors you running them on ? Sent from my DROID3 using Tapatalk 2 |
| Author: | bluebuggy [ Fri Jun 13, 2014 1:13 pm ] |
viewtopic.php?t=16085 This is my hunt. I really like the ac delco I picked up and it has more top end now so I think the summit pump was falling off some or had something to do with it coming apart. |
| Author: | Sandbar Norm [ Fri Jun 13, 2014 1:25 pm ] |
Mine is a 2.2 ecotec. Had a summit, did not last. Now a E2000, so far its been good and a lot less noise. Do you have a returnless fuel setup? If so this may save you some $. Fuel filter and regulator in one. http://www.speedwaymotors.com/LS1-Fuel- ... 41793.html Norm |
| Author: | bluebuggy [ Fri Jun 13, 2014 2:07 pm ] |
That is the same as a fuel filter you can get at AutoZone for a 2000 jeep grand 4.0 set at 55psi Sent from my SAMSUNG-SGH-I727 using Tapatalk |
| Author: | Sandbar Norm [ Fri Jun 13, 2014 4:29 pm ] |
Maybe, I don't know. I wish I had seen a filter like those. I ended up making my fuel rail a return style and then adding a reg. I could of save a bunch going with a reg/filter. |
| Author: | ImmortalSoul219 [ Sat Jun 14, 2014 7:22 pm ] |
1996 ford f150 fuel pump cheap inline pump |
| Author: | frankenbuggy06 [ Tue Jun 17, 2014 11:12 am ] |
Ended up going with a e2000 pump. 85 bucks in a lifetime warranty. Sent from my DROID3 using Tapatalk 2 |
