It is currently Mon May 04, 2026 12:21 pm
 Post subject: Front brakes
PostPosted: Thu Dec 26, 2013 6:02 pm
How can you cut the front brakes off and still have back brakes? Running disk on front and back.
 Post subject: Re: Front brakes
PostPosted: Thu Dec 26, 2013 10:50 pm
You should be able to undo your line to the front and put a plug in it some people have a seperate master cylinder for the front brakes for going down hills
PostPosted: Thu Dec 26, 2013 11:24 pm
They are a manual valve that you can buy that goes between the brake lines on the front. It almost works like a line lock on a drag car but it is not electric its manual. You will have the brake line go to the valve back out of the valve to the front brakes . Its a push-pull knob is pulled out only the back brakes will work when the knob is pushed in all four wheels will work
PostPosted: Fri Dec 27, 2013 12:21 am
http://www.jegs.com/i/JEGS-Performance-Products/555/631600/10002/-1?parentProductId=1518380
PostPosted: Fri Dec 27, 2013 5:47 am
Just goto local hardware get 1/4" ball valve then reduce to 3/16 compression and done
PostPosted: Fri Dec 27, 2013 8:28 am
Is there an electric one you can run off a toggle switch?
PostPosted: Fri Dec 27, 2013 8:47 am
hurst line lock http://www.summitracing.com/parts/huu-1745000
PostPosted: Sun Dec 29, 2013 10:45 pm
Drag Racing uses a Staging Brake but I believe that is controlled by the Transmission
PostPosted: Tue Dec 31, 2013 2:03 am
The transmission break is called a trans break totally different than a line lock the line lock works off of 12 volts solenoid . A trans brake locks the transmission and between reverse and low gear so you can hold the car still on the line . While the car is held to the floor . Your line lock is designed just for a burnout
PostPosted: Tue Dec 31, 2013 2:10 am
I know a little bit about drag racing here's a couple of pics of one of my old cars
