It is currently Tue May 05, 2026 4:04 am
PostPosted: Thu Jan 13, 2011 8:59 pm
Gonna paint my frame and I need to get that old paint off,Just one or two coats on there.We did one once before with a angle grinder with a brush on it and it was an all day ordeal.Just wondering what u guys do.Paint stripper,sand blast,or some other way?
PostPosted: Thu Jan 13, 2011 10:58 pm
Ive always sand blasted.
PostPosted: Fri Jan 14, 2011 12:08 am
There is no easy way. Other than paying someone else to do it :wink:
PostPosted: Fri Jan 14, 2011 9:10 am
easy off oven cleaner.
PostPosted: Fri Jan 14, 2011 10:52 am
x2 Chad :mrgreen:
PostPosted: Fri Jan 14, 2011 11:28 am
I would not suggest aircraft stripper.It was the biggest pain in the a$$ ive ever dealt with.Spend a few hundred bucks and get it sandblasted or spay over top of it and ride.
PostPosted: Fri Jan 14, 2011 3:49 pm
Gasoline? When I bought mine the previous owner got stupid drunk flipped it and it caught fire and burnt to the ground. That took all the paint off. :) Seriously Scotch Brite pads that fit a sander/buffer and the small ones for your air die grinder work but take time. Even wih a renting large sand blaster and air compressor it takes 2-3 hours but you also get all the rust off. Last person I know got the compresor and blaster for around $100 per day. I have never tried paint stripper.
PostPosted: Fri Jan 14, 2011 6:30 pm
all i have to say is do NOT use the "ospho" knock off shit from home depot, go to the body shop store and get the real shit. I had to sandblast my entire frame and it still barely took that stuff off. For those that dont know, "ospho" is used to pull the impurities out of the steel before painting, uc an usually knock it off wtih scotchbrite. Sandblasting a buggy frame is miserable.
PostPosted: Fri Jan 14, 2011 8:18 pm
I had mine sandblasted as well as a handfull of parts for 200.00.
PostPosted: Sat Jan 15, 2011 10:54 pm
I just use wire wheel on an angle grinder
cron
