It is currently Mon May 04, 2026 5:55 pm
 Post subject: Power Steering
PostPosted: Fri Nov 16, 2007 2:11 pm
Looking to install Power steering on my new Buggy. After doing some research on Howe etc its to expensive ($1500.00 to $2,000.00) to go that route. Has anybody done any thing different that works.
PostPosted: Fri Nov 16, 2007 2:57 pm
I am assumming your putting these on V8s and your Chain drive Buggys.
Are they rack systems or a standard steering box like the manual ones guys are installing on little Buggys. Do you have any pics of them installed. Are they installed in the center or the traditional stock location?
PostPosted: Fri Nov 16, 2007 3:34 pm
i run a charlyn torque generator off a fork lift and a 1984 honda pump with the gears flipped around in it. great setup. I know drews in hamilton sells the torque generators now and the pump i got from napa for around $100.
PostPosted: Fri Nov 16, 2007 4:10 pm
that's what I run a charlynn tork gen with a SACO rack with a pump and mt bracket off a hunda exell resavor and all was about 40 bucks the mounting bracket will weld right on to the frame I used a steel line to run from the front to the back for pressasure I used a cheaper rack on a nother buggy and it worked fine around here tractor supply co has the charlynn unit I think it's 179 +150 for a econo rack 40 to 50 in a pump [junk yard]
having
powersteering
priceless
PostPosted: Fri Nov 16, 2007 4:22 pm
i run a wright rack and never had a problem, but i have seen 2 or 3 of the econo racks fail with this set-up.
PostPosted: Fri Nov 16, 2007 7:03 pm
Quote:
Curt
PS That's a good looking rail RaceBugg. Where's that at and do they have a web site showing the track?]
check out maora racing. http://www.maoraracing.us/
PostPosted: Sat Nov 17, 2007 8:10 am
RockRockets, I priced the Charlyn here in ohio and they want $450.00 for it. Do you have a number for the one down there. Do you have pics of how you did the pump setup?
Racebug, I assume you race with that set up and it appears your rack has held up. I have been reading on other sites about that set up and a lot of guys claim that it will take out a rack in short order. Does your set up have a steering damper to help relieve the stress on the rack. I assume you flipped the gears in the pump because it would have run backwards. I have read that the Charlyn unit is a rack killer and thats one of the reasons guys went to a ram type system. They also commented that at high speeds the steering was not very stable. Have any pics of the setup.
PostPosted: Sat Nov 17, 2007 2:05 pm
THE GUY'S CALLING IT A RACK KILLER AROUND HERE JUST WANT TO SELL YOU SOMETHING . MINE IS OVER 10 YEARS OLD [KNOCK ON WOOD] IT STILL WORKS FINE. EVEN AFTER ROLLING A FEW TIMES. AND TRUST5 ME I TEND TO TEAR UP SOME SH T
TRY CALLING FORCE AMERICA . i DON'T KNOW THERE # BUT IF YOU CALL 800 DIRECTORY THEY CAN TELL YOU I THINK I GAVE AROUND 171$ FOR MINE
PostPosted: Sat Nov 17, 2007 10:40 pm
if you run a good rack (wright or saco) it should hold up just fine. yes, on the road it is kinda dartybut off road, even up in the 80mph range, you cant tell.also zero bump-steer and i've got @ 18 inches of travel.
PostPosted: Sat Nov 17, 2007 10:50 pm
thanks, chaindrive. that track in the pic is in greenup IL.
PostPosted: Sun Nov 18, 2007 2:22 pm
Do they work as well as a Ram/Servo type setup?
PostPosted: Sun Nov 18, 2007 11:05 pm
don't no but if you get up against a tree you can turn the wheel and move the buggy over that's how stronge they are
PostPosted: Mon Nov 19, 2007 9:40 am
i think they work as well as the ram\servo setup
PostPosted: Fri Nov 23, 2007 12:02 am
Where is greenup IL?I thought anything offroad was illegal in IL>
aaron
PostPosted: Sun Nov 25, 2007 7:21 pm
greenup is on i-70, about 30 miles from indiana line.
PostPosted: Mon Nov 26, 2007 10:11 pm
Do my recent findings on Ebay and the Samba I have decided to go with Servo/Ram steering. I have bought all Sweet componets off Ebay for $238.88 minus the two short lines from the servo to the ram. The Sweet pump came with a pully and a drive that I can possiabley adapt to the motor and a mounting bracket that will bolt to the frame along with the Resivoir and line and 2 - 8' lines that go up to the Servo. I also picked up a new Saco Rack with Aluminum tie rods with Hiems for $260.00 from the Samba. So for around $500.00 Im in. So I am able to have power steering with out breaking the bank. ITs a wonderfull thing! :D
