It is currently Sun May 03, 2026 2:50 pm
PostPosted: Sat Nov 20, 2010 4:31 pm
Should the bushing for the rear trailing arm fit over the part that the bolt threads into?
Thanks
 Post subject: Re: Bushing
PostPosted: Sat Nov 20, 2010 4:44 pm
Yes
PostPosted: Sat Nov 20, 2010 9:30 pm
can not get the bushing to go over this part. Any suggestions? Thanks
PostPosted: Sat Nov 20, 2010 11:43 pm
That hub should be the same size as the steel tube running through the bushing. If it's not right the bushing won't fit over it. Does the tube and bolt lign up?
