It is currently Mon May 04, 2026 4:30 pm
 Post subject: F-250 clutch
PostPosted: Wed Jun 30, 2010 12:23 pm
I need to order a clutch kit for my F-250 its a 1999 7.3, 6 speed ive called the dealer and they want $620.00 I just thought that if somebody on here can get them cheaper it wouldnt hurt to ask. All help will be appreciated.
 Post subject: Re: F-250 clutch
PostPosted: Wed Jun 30, 2010 1:17 pm
pipe dope i work at townsend ford in tuscaloosa al. at my employee discount i can get the clutch kit for 295.25 plus 9 percent sales tax. but you would also have to ship it to your house. kit includes disc, pressure plate, throwout bearing and pilot bearing.
PostPosted: Wed Jun 30, 2010 4:59 pm
Get ya an aftermarket dual disk or something from Valair, South bend, or one of those companies. You'll never have to worry about it again.
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Wed Jun 30, 2010 5:18 pm
I'm running a Valair ceramic / kevlar disc and a 3400# plate in the Dodge and I've had really good luck with it so far. It is just a tad grabby and the pedal is really firm but it still tows nice once you get the hang of it.
They also offer organtic and brass woven facings, and if I remember right those aren't much more than a stock replacement clutch.
There website is www.valairinc.com
PostPosted: Wed Jun 30, 2010 5:45 pm
Good call. Go with Valair, Brian. From the way every body on the Cummins Forum acts, they're the best to get. I'll just stick to my built auto. :mrgreen:
-Dakotah/koko
-Dakotah/koko
PostPosted: Wed Jun 30, 2010 6:45 pm
Thanks guys but jeff clay works for a clutch company that makes them for ford and he got me a hell of a deal on a factory kit.
PostPosted: Wed Jun 30, 2010 6:46 pm
Whatever floats your boat! :D
-Dakotah/koko
PostPosted: Wed Jun 30, 2010 8:47 pm
That Jeff Clay the Man 8)
PostPosted: Wed Jul 14, 2010 9:13 pm
LuK clutches and torque convertors. best there is. make majority of oem clutches and torque convertors, and pieces and parts for other companies that try to make them. wish you guys could see the machinery in our factory, it is cutting edge, and me being on the electrical end, i get to dig around in the electrical cabinets, its amazing what you can do with electricity and mechanics!
lick your fingers and twist wire nuts! :shock:
PostPosted: Thu Jul 15, 2010 1:58 am
Thank you jeff i got the truck fixed and everything went great direct bolt in.
PostPosted: Thu Jul 15, 2010 10:13 pm
Awesome i'm glad it all worked out!!
PostPosted: Fri Jul 16, 2010 6:19 pm
jeff i need a converter for a ford c5 trans i think its out of a 75 bronco ... see what you can do pp smoocher
PostPosted: Fri Jul 16, 2010 6:54 pm
C4,C6,or FMX never heard of a c5
PostPosted: Fri Jul 16, 2010 8:20 pm
C5 1982 thru 1986, not as good as the C4.
C5 was aluminum case, the C4 was cast iron.
