It is currently Tue May 05, 2026 7:33 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
PostPosted: Mon Jun 21, 2010 3:39 pm
any body know any thing about a 6.6 duramax my truck is acting up the code that is comin up is fuel rail pressure too low.....
PostPosted: Mon Jun 21, 2010 4:24 pm
Take it to a dealership so they can completely diagnose the problem and they should help you out on what causes the problem, it may just be a sensor going bad.
PostPosted: Mon Jun 21, 2010 4:33 pm
I agree with Chad. take it in, thats code could indicate a couple of problems. Bad injector or o-ring and could be filling block with feul or cylinder and can hydro-lock. Dont mess with it and get in to the shop. Goodluck, keep us posted.
PostPosted: Mon Jun 21, 2010 4:48 pm
Also check the block that your fuel filter screws onto these are known for developing cracks and causing all kind of problems...
PostPosted: Mon Jun 21, 2010 5:40 pm
The guy that works in the bay next to me does all our duramax work. I'll ask him tommorow. Pretty sure its an injector issue.If you need this truck this wknd get it to the dealer now! if its an injector its no small job to fix it.
PostPosted: Mon Jun 21, 2010 5:53 pm
Sell that DuraCRAP and buy a 12v CUMMINS!! That'll solve it all. No electronics=no code throwin'.
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Mon Jun 21, 2010 5:55 pm
the injectors have a killer warranty take it in and have them make it right
PostPosted: Mon Jun 21, 2010 6:05 pm
True, very true 8)
PostPosted: Mon Jun 21, 2010 6:07 pm
I have heard that too, somthing like 200,000 mile warranty cause so many failers
PostPosted: Mon Jun 21, 2010 6:28 pm
-Dakotah/koko
Only reason we let you get a Cummins pwrd truck was because your mom knew youd be safe in it cuz they are so sloooow! :mrgreen:
PostPosted: Mon Jun 21, 2010 6:42 pm
kybuggy1 wrote:
-Dakotah/koko
Hahahaha
Busted........ :mrgreen:
PostPosted: Mon Jun 21, 2010 6:53 pm
fuel pressure regulator i would bet and also its prob in the fuel filter
PostPosted: Mon Jun 21, 2010 7:13 pm
Bluebuggy may be right about the fuel filters, they are very important for diesel engines, if you let them get dirty even they looks fine, it makes a huge difference in fuel pressure and that is also important for the common rail diesel engines. Don't take shortcuts on your diesel truck Willie, they do not get by like you can on gasoline engines and i have been there in my younger days, I used to have a Ford Mustang and I thought it was bullet proof, I let a few things go when it should have been fixed properly and I just kept rigging it to where it will still run then it lead to failure big time!! Diesel engines are way more sensitive, hope you get it going and see you you at Wheeler's.
PostPosted: Mon Jun 21, 2010 8:42 pm
Try a AC fuel filter . what year of truck
PostPosted: Mon Jun 21, 2010 8:59 pm
its an 06 my thing is iv taken it in and the dealer charged me $190 buks and didnt fix it and now i cant get any body to look at it till next monday.iv changed the fuel filter&airfilter
PostPosted: Mon Jun 21, 2010 10:39 pm
i would start looking at the pressure at the tank i know a guy that the feed line broke in the tank and you also may just have a week pump. i fthat was not it i would just check every place the line comes off till you find it if the rail it self is low then it your regulator.
go pick up a Fuel Injection Pump Tester cheap $16 and it works good
http://www.harborfreight.com/fuel-injec ... 92699.html
PostPosted: Mon Jun 21, 2010 11:14 pm
SELL IT AND GET A DODGE :D
it could be several things such as all of the above, but im afraid that maybe your lift pump went out and has ruined the the injector pump but that is just my guess
PostPosted: Mon Jun 21, 2010 11:27 pm
first off id drive a ford be for id ever drive a junk ass dodge :twisted: the thing about it is when it act's up i can clear the code with the scaner and it will run fine for a while and then start acting up agian it hasnt acted up in a few days but that dont mean it wont when i hit the road it seems to do it more when the truck has a load on it?
PostPosted: Mon Jun 21, 2010 11:38 pm
you have a fuel rail sensor or a injector issue prob a set of injectors
PostPosted: Mon Jun 21, 2010 11:45 pm
Sounds like a lift pump more and more.
Goto www.dieselplace.com its a duramax only forum. If anyone online can help you those guys can....
Also, I bought my duramax in the fall of 06 new off the lot filter change every 10k, amsoil fuel treatment and zero problems in 135k.....
PostPosted: Tue Jun 22, 2010 12:48 am
i never had an issue till now i got mine with 19000 on it but mine just hit 136000.
PostPosted: Tue Jun 22, 2010 2:08 am
kybuggy1 wrote:
-Dakotah/koko
Thats some funny stuff there!! Just shows ol dad dont know his trucks :shock: Jr give me a yell when you wanna wake that 12v UP,,Only good running fords have 12v's swapped in em :mrgreen:
PostPosted: Tue Jun 22, 2010 8:25 am
Talked to my duramax tech at work. He said put a filter on it. If that don't work most likley an injector or pump problem. .
PostPosted: Tue Jun 22, 2010 11:04 pm
some with programs need extra pump for pressure.. Or so i was told? If not will burn pump up. MOPAR!!!!!!!!!!!!!!!!!! in my book for long pulls. Still hauling cars Wilbur,We have been picking up at Lexington lately,Toyotas . Ill call you next time im up and may have drink.
PostPosted: Wed Jun 23, 2010 12:32 pm
Yea, dirtdobber. You're thinking of a lift pump like a FASS or an Air Dog system. They keep up with your fueling better when you throw big injectors, a hopped up injection pump, (willie has a bosch cp3 pump, stock.) or a tuner, or the EFI tuning program on your truck, (Duramax-Specific tuning program) which deliver alot more #2 to that DirtyMax. But if willie doesn't have anything on his truck to increase fueling, that shouldn't be the problem. It very well could be his stock lift pump going bad, a problem with the injection pump, or somethin' as simple as a sensor going bad. Wilbur, if it ends up being a bad lift pump, I would recommend upgrading to something like a FASS or an Air Dog. They're alot more durable, help keep air out of your fuel to make sure you're getting nothing but fuel to the motor, which increases MPG, and they have two large filters.
Here's a link to an Air Dog system on Pure Diesel Power's website. This would probably be your best bet. I'll definitely be running and Air Dog 150 on my Cummins when I go to bigger injectors and turbo, and do some more pump mods to increase my fueling. You may do some more researching to find one cheaper, but I wouldn't run any brand besides FASS, Air Dog, Raptor, and maybe a Holley Blue Pump. I've heard mixed opinions about the Holley lift pumps. :D
Here ya go:
http://www.puredieselpower.com/catalog/ ... 25496.html
-Dakotah/koko
-Dakotah/koko
